Power steering filter
  • #16
    I just had the fluid changed in the power steering system in my '55 President and there was no filter. Should I be using one?
    Your '55 would have the Saginaw setup. So far as I know there is no "filter". There may be a screen someplace. The '55 setup return hose goes back into the pump body and I am not sure what happens from there. I have a '57 pump on my '53 and those have the return hose going to the reservoir/tank. There is a double layer fine screen inside. I actually had to pull this apart to clean out once when red silicone sealant I used on the cork gaskets under the tank had bits get into the system and clogged up that screen.
    Jeff in ND
    • #17
      B7A-33538-A .. Ford P/S Filter-Use with Eaton P/S pump - Does not fit 1953/56 Ford (uses AE-33538-A), 1955/57 T-Bird & 1957/58 Ford V8 (uses LA-33538-A) / Obsolete
      Info source: 1949/59 Ford Passenger Car Parts Catalog.
      MUSTANG'S ETC in Van Nuys CA has 1 = 818-787-7634.
      NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
      LINCOLN OLD PARTS STORE in Clearwater FL has 4 = 727-445-7551.
      No FoMoCo dealer, no other obsolete parts vendor has any.
      Last edited by WinM1895; 01-14-2016, 12:14 PM. Reason: Above part numbers located via rearcounter.com
      • #18
        Ref. post #14, what year and model Ford pump was used? I would like to put a filter on my '61 Hawk ('62 pump).= Jim
        • #19
          I bought a steering pump set-up from a 390 T-Bird early to mid 60's and it had the same pump and reservoir, I wanted the dipstick lid. Just look for a '65ish or earlier Eaton Ford pump. The shelf for the filter is held on by the bolt that holds the housing to the pump.
          http://shastamustangsupply.com/eaton.htm
          • #20
            From the engineer blue print at SI. Eaton ER-91638.
            • #21
              • #22
                National Parts Depot sells parts for Mustangs. The pump filter is their part number 33538-1. The retail is $15.70.
                Tom - Bradenton, FL
