Power steering filter
  • Steering: Power steering filter
    Resealed the ram, draglink and pump today (and replaced the hoses). It has an old fram filter inside the reservoir and I can't find that number or a cross. I didn't see one in the SI catalog, what is everyone using?.
    1960 Lark 259
    Eaton p/s pump
    Fram C-1654PL
    Going to check ford sites now.
    Thanks everyone.
      Only one I could find on-line was under the Ford number. Rest discontinued I guess.
      http://www.nospartsltd.com/product-p/b7a33538a.htm
        1960 Lark 259
        Eaton p/s pump
        Fram C-1654PL
        Thanks everyone.
        I used to have some NOS filters. I'll take a look in a few days.
          PM sent. I know who has some.
          Denny L
            It must have been about 1961 or '62 when Studebaker stopped using those filters in the reservoir of the P/S Pump, none of my '64's have them.
              Also...
              Cross Interchange Parts
              Factory Number
              FRAM C1654PL
              FORD B7A33538A
              GM 6436781
              GM 6436782
              STUDEBAKER 1548756
              PUROLATOR EP87
              FRAM C1654PL
                Found this Lares 199
                http://www.rockauto.com/catalog/more...nid=490&jpid=1
                In-Tank; w/ Eaton Pump; 2-1/2" OD x 1-1/8" ID x 1-9/16" Tall
                $9.13
                  $9.13
                  Sure looks like it... Good find!
                  http://www.larescorp.com/products/
                    What is involved/required to install this filter in an Eaton pump? Any magic? Additional parts?
                    Thanks
                    John
                      Thanks
                      John
                      I'm not sure what the newer pumps look like, but the one I have has a shelf in the reservoir to hold the filter. So I guess you could just replace the reservoir if yours doesn't have the shelf and get the spring and washer.
                        Thanks.........I'll find a Ford setup and get a first hand look.
                          I just had the fluid changed in the power steering system in my '55 President and there was no filter. Should I be using one? If so, I would love to get one of the ones mentioned above. Anyone care to comment and/or provide a filter?
                          Ed Sallia
                          Dundee, OR
                          Sol Lucet Omnibus
                            (taken from memory)
                            I swapped a Ford (Eaton) power steering tank w/filter and cover onto my '61 Hawk 289.
                            Did it to get a filter, and a dipstick.
                            There are a bunch of places to get this stuff...if you search around.
                            NPD has some of it....
                            https://www.npdlink.com/store/catalo...yle-373-1.html
                              I suspect that a small magnet would be equally effective.
                              The only debris possible would seem to be ferrous.
                              '64 R2 back on da road again
