I think the 59 hawk we have may sit a little low in the rear. Especially with passengers in the rear seat. Most of the pictures I have seen the rocker appears to be nearly parallel with the road. Our's is not. How is the correct way to correct this? I don't want a rough ride from addition of another leaf. Has anyone had good long lasting results with "spring re-arching"??
Rear ride height on 59 hawk
Spring sag is the natural order of things. Entropy never sleeps.
Yes, spring re-arching helps. No, it doesn't last indefinitely. The more load carried, the sooner it sags again.
New springs from Eaton will last longer than most of us will be driving our Studes.
Yes, pretty soon someone is going to suggest air shocks which can be increased in pressure when rear seat passengers are carried. It solves the problem, maybe. The downside is the rear crossmember to which the top of the shocks mount wasn't designed to be load-carrying. Seen more than one fail when used with air shocks or spring-type load levelers.
jack vinesPackardV8
Originally posted by RDWEAVER View PostI think the 59 hawk we have may sit a little low in the rear. Especially with passengers in the rear seat. Most of the pictures I have seen the rocker appears to be nearly parallel with the road. Our's is not. How is the correct way to correct this? I don't want a rough ride from addition of another leaf. Has anyone had good long lasting results with "spring re-arching"??
One alternative is to install over load shocks, you know, the ones with an external spring. This will give you an inch or two of lift and if you buy the shocks at Orielly's or other similar store you can get a lifetime warantee. . Another option is to buy a single spring from a spring shop long enough to reach the ends of the original top leaf. Spring shops sell individual springs just about any length and width. This is what I'm going to do to my Silver '59 Hawk.
Good Luck,
Treblig
They used to make bolt on springs that were a half leaf long. I put some on the sagging rear of a 52 rambler and it improved the ride height. Over time, it will probably bend the leaves more, but it's working for now. Newer versions are full leaf, but do not require taking the original leaves apart.
Heliwig is a good company for this type of thing. Here is a picture of something similar.
http://www.jcwhitney.com/hellwig-ez-.../p3055504.jcwx
http://www.sdtrucksprings.com/index....oducts_id=1249Last edited by RadioRoy; 12-03-2015, 10:17 AM.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
60V-L6 - 60 Lark convertible
Originally posted by Treblig View PostIf you get your springs re-arched be sure to go to a shop that has a furnace. If the springs are not heated to a certain temperature the re-arching will not last very long at all. Many spring shop use a big press to re-bend the springs, this method is a waste of money. Springs are made of spring steel and require high heat to reset the spring arch.
Good Luck,
Treblig
Originally posted by Kato View PostI'm going with single spring option for my 62 GT as well. I am heeding the warnings about using air shocks or spring over load leveling shocks because of the potential for damage at the upper mounts. They weren't designed to carry that much load. I've also been told the full length extra spring will raise the car somewhat but without creating the harsh ride that a shorter stiffer spring might. Anyway, that's what I've been told, for what it is worth!
PS - Good point about the upper shock mount strength!!!
Treblig
Originally posted by PackardV8 View PostSpring sag is the natural order of things. Entropy never sleeps.
jack vines
On several Studes, I have simply removed the longest leaf from a spare set of springs, and added it. I did that on a 56J many years ago, and it still sits and rides well. The ultimate fix is a new set of springs. The last ones I bought were from Dave T-bow for the wife's 63GT. They fit perfectly, and the car sits and rides well. If buying new, be sure to get the HD version. If buying NOS, the HD versions are all but unobtainium. NOS standard duty springs are fairly common, but I would not install a set if someone gave them to me.
I had a bad experience with Eaton Spring Co., and would not buy from them again. To fix what they sent me for the 62GT, I had to add an extra (longest) leaf from the old springs. The self proclaimed expert on the phone insisted they had sent me the right rate springs, but he was FOS. Those springs would bottom out if driven over a horse turd.
If cutting an extra main leaf, to length, be sure to allow a few inches on each end. If cut too long, it will butt up against the eyes on the original spring, and effectively lock the suspension up. Also, be sure to taper the ends, or they will eventually cut through the main spring.
