Tightening body to frame bolts. Feedback appreciated
  • Body / Glass: Tightening body to frame bolts. Feedback appreciated
ID:	1748847Click image for larger version
ID:	1748848Click image for larger version
ID:	1748849Click image for larger version
    I would guess tight would work. I think I would use a locking nut rather than a lock washer. I would think it would be less likely to come loose.
      Steve,
      I did use the locking nuts on the bolts under the body. I am very thankful for your suggestion. I will check to see if there are access holes under the frame below the screws that go into the frame. If so, I will run a lock nut up from underneath and lock the screw into the frame.
      Charlie D.
        I wouldn't bother with a lock nut on the bolts going into the frame. After fighting the bolts on my 59 wagon I have used anti-seize on those bolts. As far as torque goes tighten them down to at least 25 ft/lbs & then be more concerned with the body alignment especially those in the area of the "A" pillar. Those will be a major effect on the front doors align to their adjoining panels. When I have the wagon all lined up I have a reinforcement made to strengthen the "A" pillar to the outermount of the crossmember (or batwing). It will be welded to the floor & pillar on the inside before a coat of POR15 & spray bedliner to prevent any future rust issues.
        60 Lark convertible V-8 auto
        61 Champ 1/2 ton 4 speed
        62 Champ 3/4 ton auto
        63 G.T. Hawk R-2,4 speed
        63 Avanti (2) R-1 auto
        64 Zip Van
        66 Cruiser V-8 auto
          https://www.danchuk.com/images/Downl...djustments.pdf
          Danchuk has some useful information on body mount shims in their newsletter.
          567 Update, Volume 11, Issue 2.
          They discuss torque.
          Pay close attention to door gaps as shown on page 3.
          "Follow closely because where you think shims should be placed is not necessarily the correct place."
          raylinrestorations.com has Studebaker specific info on their "Studebaker Body Assembly and Alignment" page.
          South Lompoc Studebaker
            That's good information Dan. Useful with Studebaker except for the part on front door hinges. Where they bolt to the "A" pillar there is no provision for adjustments on Studebakers. That part of the hinge bolts on without the ability to move.
            64 Zip Van
            66 Cruiser V-8 auto
              Warren true Studebaker didn't make an adjustment in the hinge but if needed you could build your own with slotted holes or shims.
                Thank you for the information and the link to the Danchuk article. I have referred to the Raylin site several times already but never saw the body panel alignment suggestions. It makes the reassembly of the car look a little daunting.
                Charlie D.
                  The few Studebakers I've taken apart have a shim made the outline of the hinge strap where it bolts onto the door. The shim isn't smooth but is stamped with "teeth" sort of like it was hit with a meat tenderizer.
                  64 Zip Van
                  66 Cruiser V-8 auto
                    I bought a pack of 10 door shims for doors in South Bend back in the 80s. They sure looked like factory shims to me. 3 holes all different thickness.
