GH Wheel Bolt Pattern
  • Wheels / Tires: GH Wheel Bolt Pattern
    What is the bolt pattern for the '56 GH 15" wheels? What other of the "Big Three" wheels are the same pattern? Thanks, guys...
    Studebaker 4-1/2 " on 5" same as other wheels.
    Candbstudebakers
    Castro Valley,
    California
      Very common bolt pattern used by Ford, Chrysler & AMC.
      60 Lark convertible V-8 auto
      61 Champ 1/2 ton 4 speed
      62 Champ 3/4 ton auto
      63 G.T. Hawk R-2,4 speed
      63 Avanti (2) R-1 auto
      64 Zip Van
      66 Cruiser V-8 auto
        Is it GM that used the 4 3/4" bolt pattern?
          Before you grab the air impact, check to see if the lugs are all right hand, or if one side is left hand threads.
          Paul
          Winston-Salem, NC
            LOL. Good advice the check. The left handed studs should have an "L" in the end of the stud....but ya never know!!!
              Yes, GM Cars are the ODDBALL!
                Thanks ALL...
                  A few guys years ago liked the Dodge Aspen wheel that was used on police cars because they bolted up and gave a wider wheel without clearance problems. They used to be around in wrecking yards, but most of the stuff has disappeared unless you find an older pick your part place. You could use stock wheel covers on those wheels.
                  Bob Miles
                  Tucson AZ
                    15" x 6" wide wheels, 5 on 4 1/2" with 4" backspace came on:
                    Ford Ranger, 93-09
                    Ford Explorer, 93-94, 96-00
                    Mercury Mountaineer, 97-01
                    Mazda B2300, 2000
                    Some Rangers came with a 14" wheel. You want the ones with 8 oddball shaped ovals on the center.
                    Stock wheelcovers fit the wheels.
                    South Lompoc Studebaker
                      GOOD info o the wheel interchange...
                        Moved to Tech Talk. Please guys, put 'em in the right board.
                          Ford Ranger, 93-09
                          Mazda B2300, 2000
                          Mr. Prez,
                          Would you happen to know what (late) vehicles used 15 inch rims with 5 X 4 1/2 bolt pattern and 3 3/4" back space. I have a '59 Silver Hawk with modern disc brakes on it and need two steel rims 7 inches wide. I'll probably be selling the original rims and the spare rim.
                          thanks,
                          Treblig
                            Which modern disc brakes? Most of the mentioned wheels will fit, 3 3/4" vs. 4" back spacing probably won't be a problem, just choose one that came with disc brakes originally, most listed did. Going to 7" wide rims may be a problem, you might get the right off set, but wind up with tires rubbing your wheel well openings. Lots of prior posts on wheel sizes and fit--best bet is a 15 x 6 max.
