6V electric fuel pump
  • Fuel System: 6V electric fuel pump
    Has anyone done this and recommends a particular electric fuel pump over another? Where do you get the cover plate to closeup the original fuel pump opening?
    Here's a link to 6 volt pumps.
    https://www.google.com/search?q=6+vo...utf-8&oe=utf-8
    They are reliable, alcohol resistant, etc.... Make sure you put a filter before the pump and a safety switch in line with the power supply..
    The stock fuel pump can be removed and the hole covered with a GM SBC(350) block off plate.... Just did the same thing..
    64 GT Hawk (K7)
    1970 Avanti (R3)
      You don't "need" a 6v pump.
      I've got a Carter, (12v) P4389 pump on my 6v Conestoga.
      http://www.summitracing.com/search?S...&keyword=p4389
      I set up the fuel system for the new engine it will get one of these days, a hot rod 299. This includes the 12volt Carter pump.
      I actually had to adjust the pressure regulator all the way down to lower the output pressure low enough to properly feed the flathead six single barrel carburetor.
      Been there for a coupla years and more than a few thousand miles without problem.
        I have a 6 volt Carter (Precision from O'Reilley's) and two 12 volt Holley pumps. I like them and use a resistor to reduce the voltage to 3 volts, which gives the right volume and pressure for my 50 Champion.
