I am wondering the right way to go about freshening up the grill on my 62 GT. The hood is coming off for a respray to take care of some rust and I have noticed the grill has some slight rusting. What is the best way to deal with this, paint? Is it stainless steel? Not sure if the photos show the rust very well but here they are:
Grill Refinishing
Try 0000 steel wool.Bez Auto Alchemy
It's a nickel alloy, I bet. A mild acid would remove the rust, even some CLR. If you have time, keep wiping it with Coca-Cola and the rust should go away. A new one could be prone to the same rusting. Good luck. Looks like we may get rain for IDYSD.Dave Warren (Perry Mason by day, Perry Como by night)
[QUOTE=warrlaw1;942998]It's a nickel alloy, I bet. A mild acid would remove the rust, even some CLR. If you have time, keep wiping it with Coca-Cola and the rust should go away. A new one could be prone to the same rusting. Good luck. Looks like we may get rain for IDYSD.[/QUOTE
CLR! I hadn't thought of that, great idea especially when it's off the car! Yes, not looking good for Saturday is it. I am OK with light showers but until I get that windshield sealed up I'll have to avoid heavier rain it just pours in! Let's see what the forecast is for Sat on Fri night and make the call then?
Originally posted by warrlaw1 View PostPerfect. Bromley Automotive just called and my car is ready for pick-up. I had to get a few parts fastened down so they don't fly off at the races
I've used some stuff called "Quick-Glo" that cleaned up the grille for my 59 wagon like new. It comes as regular & fine & has a bit of wax in it to help rust from coming back right away.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Originally posted by sals54 View PostIf you use 0000 steel wool, be sure to use a lube with it. WD40 works well. Then soap n water clean up. Then a car wax.
