Hi,
I have a '57 Golden Hawk; was fortunate enough to find NOS front brake drums, but need to use my old hubs. So, will need to use new studs, which I've purchased as well.
QUESTION:
REMOVAL: I have a bearing press; my plan was to "simply" support under each old stud, press them out (any heating or other tricks required to prevent damaging the old hub?). Were they swedged in, or just press fit (thus 'pressing back out" sufficient and harmless?). I'd rather ask than damage them, though almost sure you'd just 'press them out'...
INSTALLING NEW LUGS: I was going to reverse the process, support the new stud area of the hub, press the new studs in.... BUT, am assuming I should THEN take two drums/hubs to a machine shop (our local auto repair shop says they have a tool forsomehow locking in wheel studs...) and have them 'dimple' or swedge or whatever the technique is to lock them in place tight enough to resist modern impact wrenches and such......
When I got the car, the previous owner (I'll refrain from foul language) had literally used silicone to hold the studs in place from inside the drum; good for one-time tightening of lug nuts; and of course spun immediately when I tried to remove the wheels. Being 'mag' wheels they'd put on, what a treat it was to try and drill out those studs through the deep cavity of alloy wheels (lugs wanted to spin with drill, too!). I'm sure the "left-hand thread' demon was showing up here, was only that side of the car..... Some grease-monkey kid tried to remove the originals with an impact wrench and ruined them I'm sure, as everything else was good.
Anyway, I certainly don't want my wheel studs turning on me or anyone else someday, and impact wrenches give quite a jolt, so just pressing them in alone doesn't seem sufficient.
Can someone confirm if I'm correct, or missing a key point in the process here? (or overly cautious? Press-in sufficient to withstand future torque?) Thanks!!
Barry
QUESTION:
Barry
