Trying to pull the sending unit on my GH to check and replace the float. Are there any special tips on getting the gas line fitting loose? Looks like it's never been removed before. Seems like you have to be a contortionist to get to it and have any leverage, have it soaking in penetrating spray now.
57 Sending Unit/Gas Line Connection
On my 57 Clipper I enlarged the access hole with tin snips toward front of car. Could then get wrench to remove gas line fitting. Decided this was better than laying under car trying to get needed leverage. Added benefit is dirt does not fall up into your eyes when working from trunk rather than under car. When complete made sheet metal cover and attached with screws just use caution when drilling holes for cover as to not go into tank just floor of trunk. Use tubing wrenches not open end or cresent wrench.
Originally posted by Mark Klinger View PostThanks for the advice and mentioning the flare nut wrench, sure don't want to round that fitting off. I had considered that may be the only way to get enough access to the fitting and the opening doesn't need to be enlarged too much. What were they thinking when they designed that??
Originally posted by tim333 View PostI had no trouble lying on my back with the proper wrench getting it loose. Just jack the car up high enough, set the jack stands and have at it. Mine was a 57 Commander.
Cover, Trunk, Gas Tank Access Hole
I found an inexpensive cover for the gas tank sending unit access hole in the C and K trunk. It's an electrical outlet cover that's powder-coated aluminum and comes with a foam rubber gasket. It has two round-head machine screws with it so you'll have to use two sheet metal screws instead of the original three. It's 4-⅛" diameter and fits perfectly in C & K trunks (don't know about others.) It's less than $3.00 on Amazon. It's light gray and you might have to spray paint it your trunk color. There is a statement "Suitable for Wet Locations" stamped on one side with small letters. The other side has the UL information. It's from Hipp Modern Builders Supply, Mountain View, AZ 72560, P/N C452759, via Amazon.
Bill L.
1962 GT Hawk
Originally posted by doofus View PostMark ,wound up doing cut n patch on 56 wagon. didn't ever get line stub loose even in vise. cleaned line with chemicals and added marine grade fuel hose connector and filter. Luck Doofus
