What is the thinnest spacer.......
  • Cool/Heat: What is the thinnest spacer.......
    ...made to insert between water pump pulleys? Any available?
    64 GT Hawk (K7)
    1970 Avanti (R3)
    Just make what you need..!
    It's hidden, it doesn't have to be beautiful..!
      Just wondering why you're asking? Are you having cooling issues?
        http://www.summitracing.com/search?P...ulley%20spacer
        Best Keyword Match Default Sort Product Line (a-z) Product Line (z-a) Part Number (a-z) Part Number (z-a) Price (low-high) Price (high-low) New Arrivals Should Ship By Spectre Performance 4480 - Spectre Performance Water Pump Pulley Shim Kits
        Compare
        Water Pump Spacer, Water Pump Pulley Shim Kit, 0.0625 in. Shims, Chevy Water Pumps, Set of 3
        (4)
        Part Number: SPE-4480 More Detail...
        Estimated Ship Date: Monday 7/13/2015
        $4.97
        KRC Power Steering KRC15050030 - KRC Power Steering Water Pump Pulley Shims
        Compare
        WATER PUMP PULLEY SPACER .030" THICK
        Not Yet Reviewed
        Part Number: KRS-KRC15050030 More Detail...
        Estimated Ship Date: 7/27/2015 (if ordered today)
        $5.30
        KRC Power Steering KRC15050170 - KRC Power Steering Water Pump Pulley Shims
        Compare
        WATER PUMP PULLEY SPACER .170" THICK
        Not Yet Reviewed
        Part Number: KRS-KRC15050170 More Detail...
        $24.78
        QuickTime RM-716 - QuickTime Pulley Spacers
        Compare
        Water Pump Spacer, Steel, Zinc Plated, Chevy, Small Block, Set of 3
        Not Yet Reviewed
        Part Number: QTI-RM-716 More Detail...
        $22.97
          Thanks for the returns.
          Mike: I currently have a home made spacer.... (made from an aluminum "speed Limit" sign, my son brought home once back in the 80's) Best material to make a lot of auto things with... It however wasn't much better than the close tolerance stainless steel washers used previously.
          Jeff: Yes, thanks. I just found these yesterday and will be looking at what is available.
          John: My GT Hawk has A/C and when purchased had so may things wrong that seeing a wobble in the WP pulley didn't happen. During the course of rehabilitation, installed an Avanti water pump, after which the outer WP pulley for the A/C, appeared not to align with the crank pulley. So all this re-engineering ensued.. and the fan has been changed to a six blade thermostatic one, making balance more critical.
          First try was standard washers, but you can't find two with the same thickness. Stainless washers are much more uniform, but even with them, there's a noticeable wobble. Third try was the aluminum item made from the sign. So barring the possibility that the pulley is bad, I'll see what these spacers have to offer.
          thx
          64 GT Hawk (K7)
          1970 Avanti (R3)
