Body mounts welded to stainless steel Avanti frame
  • Body mounts welded to stainless steel Avanti frame
    Just finished this recently:
    *Drilling the two rear body mounts to match the roll bar.
    *Drilling the two side body mounts to secure the floor pan at the front seats.
    *Fabricated the two body mounts at the firewall.
    *Shimmed all the body mounts to the floor pan.
    *Bolted all the body mounts to the roll bar, floor pan, and firewall.
    After checking all the mounts for squareness to frame and being level, tacking them to the frame.
    We then removed the body from the frame, and prepped the frame for TIG welding the body mounts.
    Assembled the side pipes, and installed the silicon grommets for noise and heat isolation.
    sigpic 1963 Studebaker Avanti: LS1 motor and T-56 transmission have been moved rearward, set up as a two seat coupe with independent rear suspension. Complex solutions for nonexistant problems.
    I should live long enough to be such a craftsman... [:0][^]
    Clark in San Diego
    '63 F2/Lark Standard
    www.studebakersandiego.com
      Beautiful, Gene [].
      Whatever you do...DON'T PAINT IT!
      Bellingham, WA
        Thanks for the kind words.
        Here is a brief slide show if you want to see some additional photos.
        http://www.electro-dynamics.com/chas...antislide.html
          All I can say is WOW !........The street rodders will be very jealous !
          1961 Hawk 4BC,4-SPEED,TT
          Lewisville,NC
          Ken Byrd
          Lewisville,NC
            Very awesome work. Keep it up.
            got my '59 Lark
              you have a frame and you took off the hog boxes is that very bad for the body no suport in body
