halogen bulbs 1157 ?
  • halogen bulbs 1157 ?
    jc.whitney has them for 10 bucks a pop.
    anyone know of other suppliers?
    Any local auto parts store should have them for that price. A quick internet search shows them as low as $6.99.
    David
      thanks dave,but i tried walmart, napa,carquest,
      & several others to no avail. please let me know
      if you find one! JNP
        [/quote]There are about 3,4,5? "sizes" of Walmarts, the larger ones have a major range of inventory, while the smaller ones have a lot of a very much reduced inventory. You may need to get to a "very big" Walmart to find what you want. We have a "larger" one here, and I saw the light there. $7.99
        [quote]quote:Originally posted by imitiday
        Terry,
        1963 Avanti R2, 63SR1065 http://sterkel.org/avanti
        1985 Kubota L2202 (Diesel)
        2000 VW Jetta GLS
          I didn't know that 1157 type bulbs were available in halogen! Seems like they could burn hot enough to melt the plastic brake or turn signal lenses. Just a thought to ponder.
          [img=left]http://rocketdillo.com/studebaker/misc/images/Current_Avacar.gif[/img=left] - DilloCrafter
          1955 1/2 Ton Pickup
          The Red-Headed Amazon
          Deep in the heart of Texas
          Paul Simpson
          "DilloCrafter"
          1955 1/2 Ton Pickup
            I remember reading about the super bright turn signal bulbs melting
            the plastic lenses, so make sure you check that out. This is why the
            LED boards are a 'better' alternative - practically no heat.
            Tom
              The 1157 is a 12 volt bulb. For those of us still on 6 volt, the original was 1158 with non-indexed pins, the modern 6 v. bulb with indexed pins is 1154. If you want LED's in your 6 volt positive-ground car, Stude guy George Rohrbach at High Speed Motors has them in both versions. Lots of light, no heat, low current draw.
              See http://www.highspeedmotors.com/
              Here are some pictures of my M5 without the lens and with the lens on the taillight housing. I used George's lights with the ring of extra LEDs around the outside.
              Dartmouth, Mass.
              '48 M5
              '65 Wagonaire Commander
              '63 Wagonaire Standard
              Gary Ash
              Dartmouth, Mass.
              ’41 Commander Land Cruiser
              '48 M5
                DesignTech International, in Springfield, Va. http://www.designtech-intl.com/ , is J.C. Whitney's supplier.
                A few years ago, they exchanged bulbs I had bought from JCW, for the correct version, and will replace them free, for life. They are real nice folks.
                The "1157 Super Bright Halogen Stop/Turn Bulb" two pack was #20112 @ $18.95. One bulb was $9.95.
                Turn/Brake is 30W; Tail/Park 5W. They are supposed to appear 50% brighter than the stock bulbs. I measured current draw at 2.4A and .7A @ 12.5 to 15V.
                They produce other versions, including one with a single element, staggered lugs, and two contacts. Maybe it's for backup lights. Make sure you get the right version.
                I replaced sockets and improved grounds in preparation for the halogen bulbs; and found the stock bulbs were so much brighter that I didn't need the halogens! Grounding the sockets to the rearmost body bolts, in the corners of the trunk, made the biggest difference.
                Mike M.
