starter
  • starter
    Thank you both very much I really appreciate the help, one other thing though, I dont have the 6 volt starter either! Any ideas where I can pick one up at a decent cost?
    starter
    Hello everyone, Im new to the boards and have a question, Im converting my 1949 champion from 6 volt to 12 volt and dont know what starter I should be looking for and also need to know if Im going to need a 12 volt starter switch that goes on the floor boards.
      Use the "search" function and look up 12 volt conversion.
      I believe the 6volt starter is fine to use in a 12 volt system. The starter switch should be okay -- the 6volt wiring is generally heavier than 12 volt wiring. (that is a good thing)
      53commander HDTP
      53 Champion HDTP
      61 Cursed Purple Hawk
      64 Champ long bed V8
      53 Hudson Super Wasp Coupe
        Kerry's right. The 6volt starter should last a LONG time on 12 volts. No need to change it!
        What you DO have to worry about is the Overdrive relay and solenoid (assuming your car HAS OD.) Also the heater and defroster motor if so equipped.
        Miscreant adrift in
        the BerStuda Triangle
          And wiper motor, if it is electric. Also add a ballast resistor to the coil.
            I see you say you don't even have a 6 volt starter. Well, it would be easiest if you could FIND a 6volt starter because the teeth on the drive end are of a different count than those on the 12 volt units and that count (numbe of teeth) is critical to match up with the tooth spacing on the flywheel ring gear. One might actually work with the other - but not for long![xx(]
            Miscreant adrift in
