Hello, I have a Studebaker 259 out of a 61 Lark in my 31 model 54 coupe. I bought the engine used and would like to run it to see if it's any good or not. If I understand correctly,this was a six volt set up and my guestion is to fire this engine with 12 volt,what needs to be done? Do I need the 12 volt coil for a six cylinder or eight cylinder, will the points and condenser hold up ? If I can get this motor running and it s ok, I plan to put a Per Tronix kit in the distributor but would like to hear her run first. Any help appreciated. Thanks
Studebaker 259 engine
It doesn't matter in any case.
Engine wise, the only thing that cares is the coil. So if you use a 6V coil, use a 6 volt battery. A 12 volt coil, a 12v battery. Starter wise, a 6v starter will live fine on 12v as long as you treat it with care (don't grind on a nonstarting engine).
Positive and negitive grounds don't matter either, just treat the coil correctly.
Originally posted by 32cruisin View PostIf I can get this motor running and it s ok, I plan to put a Per Tronix kit in the distributor but would like to hear her run first. Any help appreciated. Thanks59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
