Will a 1960 Lark V8 standard transmission Delco starter fit my 1963 Avanti R2? I'm told pre-61 Delco starters generate as much torque as the R2 starter. My R2 starter needs work. Thanks.
1960 Lark Starter
So that means you have a 4 Speed Standard Trans. then right?
If not, there is no way a 3 speed Manual will fit an Automatic with out changing the (Bendix) extension Housing, and the Armature and then what is left?
The OTHER problem is, we have not figured out yet what was different about the 4 Speed Prestolite Starter vs the 3 speed manual.
This is not only a Jet Thrust/Avanti 4 Speed, issue as the Starter on all 4 speeds is reportedly DIFFERENT, but how?StudeRich
Originally posted by StudeRich View PostSo that means you have a 4 Speed Standard Trans. then right?
Originally posted by rkapteyn View PostI do not think they will work for long.They fit but are to short.
See
https://www.studebakerparts.com/stud...s/starter.html
Robert Kapteyn
Len
Tom, I would certainly try the '60 Lark V8 Delco Starter as long as it is as you say, a Std. Trans. unit.
We know it is not "Correct" for this Car, but I think it is worth a try as it should work. Since we never figured out what is different B/T 3 and 4 Speed Starters, it may not be a big difference but no one is SURE.
See the latest on this, on Post #29 over here on the General:
http://forum.studebakerdriversclub.c...ers-were-thereStudeRich
Originally posted by StudeRich View PostTom, I would certainly try the '60 Lark V8 Delco Starter as long as it is as you say, a Std. Trans. unit.
I'm in the process of buying the '60 Lark V8 std. starter. Here is a link I found that shows a 1/8" difference in the 3-speed and 4-speed starters.
Tom
OK, I received the rebuilt 1960 Lark V8 4-speed starter and the nose looks very much like that of the Prestolite 4-speed starter, being 2-1/8" long. It is shown here next to the MDY 71023 2U starter that came out of my 1963 R2 4-speed Avanti, which looks like it has the 3-speed nose, i.e. 2" long. The Avanti starter was too weak to turn the engine over briskly, so I'm hoping the rebuilt Delco starter will do a better job.
I think it will fit, but doubt it will spin the higher compression Avanti engine any faster, I think the Avanti starter has different windings and the case is a slightly larger diameter, supposedly higher torque ratings. If it doesn't work, take apart the brush side of the Avanti starter, polish the commutator and check the brushes are still useable. If cleaning it doesn't work, send it out to a local electrical shop to check the windings. Before doing anything else, replace both the battery cables and the cable from the starter to the solenoid. Use the largest gage you can find, and make sure the ground side of the negative cable is attached to clean fresh iron. Also have the battery load tested. Just because a charger says it's fully charged, and a hygrometer says its fully charged doesn't mean it's good. Especially if it's a 63 with an 3E type battery--life span is 2 years max!! Ask me how I know!! Funny how a brand new 3E spun the engine like a fan, when the old one just got the solenoid to rattle. If you have a good 3E it was rated at 54 amp hours, 485 CA and 400CA at 0 degrees, but you only have a 35AMP alternator, it will never fully recharge the battery if you run it down cranking over the engine. Besides there is something about the 3E design verses the more common 27 and 24's that won't let them last as long, besides rarity, I'm sure that's one reason they changed in 64 to a "normal" battery.Last edited by karterfred88; 03-12-2015, 12:57 PM.
Originally posted by karterfred88 View PostI think it will fit, but doubt it will spin the higher compression Avanti engine any faster, I think the Avanti starter has different windings and the case is a slightly larger diameter, supposedly higher torque ratings. If it doesn't work, take apart the brush side of the Avanti starter, polish the commutator and check the brushes are still useable. If cleaning it doesn't work, send it out to a local electrical shop to check the windings. Before doing anything else, replace both the battery cables and the cable from the starter to the solenoid. Use the largest gage you can find, and make sure the ground side of the negative cable is attached to clean fresh iron. Also have the battery load tested. Just because a charger says it's fully charged, and a hygrometer says its fully charged doesn't mean it's good. Especially if it's a 63 with an 3E type battery--life span is 2 years max!! Ask me how I know!! Funny how a brand new 3E spun the engine like a fan, when the old one just got the solenoid to rattle. If you have a good 3E it was rated at 54 amp hours, 485 CA and 400CA at 0 degrees, but you only have a 35AMP alternator, it will never fully recharge the battery if you run it down cranking over the engine. Besides there is something about the 3E design verses the more common 27 and 24's that won't let them last as long, besides rarity, I'm sure that's one reason they changed in 64 to a "normal" battery.
