Front end feels loose when driving
  • Steering: Front end feels loose when driving
    I have a 1957 Packard Clipper
    Can Steering Box be adjusted?
    Checked all tie rods & ball joints tight - lot of play in steering wheel.
    Ideas for good source for front end parts?
    Cell# 8323872377
    Home 2816892958
    Tim in Texas
    The Studebaker Shop Manual describes the steering gear adjustment process, there is the stud and locknut on the outboard side of the box. The adjustment is very precise (touchy) and must be done correctly and gently to prevent damage.
    Have you checked for play or looseness in the Center Pivot Bearings and Bellcrank?
    Worn Bearings on the pivot shaft or a loose clamp bolt will produce slop at the end of the Bellcrank that connects to the 2 Tie Rods.
      The steering coupler can wear out, and it's almost impossible to see. It's hidden inside the lower steering jacket on the Saginaw power steering boxes.
      http://www.larescorp.com/
      These people can rebuild it properly. This is a side view of it, and the adjusting nut for the manual part of the gear is the nut on the side with the slot in the middle.Click image for larger version
      Bez Auto Alchemy
        There used to be a few NOS couplers out there for sale....If your car indeed needs the coupler Brad mentioned, I'd check with S.I. or one of the other Stude parts vendors first. (Same coupler, all Studes and South Bend Packards with the Saginaw P/S.)
          SI still has the coupler, or they did a few years ago. I usually replace them anytime the PS is apart, just to take up as much slack in the system as possible. They wear out real quick when folks try to drive the car without the PS working. It is not designed to carry the load involved when the PS is not working. Otherwise, they wear very little
            Cell# 8323872377
            Home 2816892958
            Tim in Texas
            First, I would check the simple stuff, like the tightness of the center pivot cinch bolt.
            Be sure to know exactly where the play is before attacking any part of the system.
            The car has king pins, not ball joints, so I question your knowledge of, ability to diagnose and ability to repair this steering system.
            I would start with SI for parts.
              And in case you are brand new to Studebakers, SI is Studebaker International.
              http://www.studebaker-intl.com/
              Don Wilson, Centralia, WA
              40 Champion 4 door*
              50 Champion 2 door*
              53 Commander K Auto*
              53 Commander K overdrive*
              55 President Speedster
              62 GT 4Speed*
              63 Avanti R1*
              64 Champ 1/2 ton
              * Formerly owned
                The center pivot would be the first thing I checked too. I had a loose one once and was relieved that a little adjustment solved my problem.
                  Thanks guys, I have a mechanic that has worked on older cars and he came over and we raised the car and could not really see anything that needed replacing. So I will pass along all these great points and see if we can get this issue solved or at least understand if there is room to adjust further the steering!
                  Also is there a place I can get a PDF of the shop manual to down load?
                  Moondog
                    Moondog
                    There are a couple experts around Texas that know the Studebaker front end, inside and out. Barry Hackney in Houston, Mark Frank in Lorena, The Jones Brothers in Harligen (Rio Grande Valley), Brian Austin in Gatesville, B.B. Holland in College Station. Not sure where Splendora is, but one of these fellas is bound to be able to help you, might even save you a lot of money. It's obvious to me that your mechanic, even though he has worked on older cars, really has no idea what he's looking for in diagnosing your particular front end problem. It may be a little effort on your part, but getting someone who knows the front end to help you is really going to save you time and money.
                    Bo
