Have a 64 Hawk, 289ci. Looking for better handling rear shocks than OEM if possible. Saw a couple of threads a while back discussing shocks and put out some numbers but when I looked them up the upper mounts were not correct (not a bolt through). Any Hawk or other compatible model guys out there have any shocks on your vehicles that have worked. Thanks, everyone has been real helpful as I learn the ways of the Studebaker.
Rear shocks
I can't give you numbers just yet as I am not at home but do yourself a favor and grab a copy of a shock manufacturer's application book. An auto parts store might have a copy you could keep. Then look for appropriate compressed and extended length. Then look for top and bottom eye styles. Some can be changed just by pressing out bushes or similar work. Most suppliers don't list Studebaker so find one that does and start cross referencing. It a bit of work but I have found plenty of usable parts that way. At the moment I have Plymouth Fury police car shocks at the rear. They came with a helper coil, but that can be taken off. I had to press out the bushings to put in the right length tube at top but they work well. I used them with the coil before I rebuilt the spring packs and added a leaf.
Len.
The Buick cross reference is also from a 50 year old car! Try 71-80 Camaro. All kinds of performance shocks are available that WILL fit the Studebaker . Take your pick, Koni, Bilstein, Etc.Bez Auto Alchemy
Yes, you do have to :
1) either press out the bolt bushing and replace it in the new shock, or ...
2) cut the "ears" of the flat bolt ends with a hack saw, and file out the tube round for a bolt, then make up the slack with a stack of washers.Last edited by bezhawk; 12-19-2014, 07:20 AM.Bez Auto Alchemy
Has anyone had success with the use of the still available Koni shocks (for the 71-80 Camaro) on an Avanti? What ride setting did you set the Konis up with (firm, medium or soft)? I would think the Camaro is a significantly heavier car than the Avanti, at least on the rear axle. Perhaps the front Konis are a good fit ride-wise for the Avanti, due to the heavier Stude V8 engine?
Any comments on the use of these still available Koni shocks on the Avanti would be appreciated.
Originally posted by Mangusta1969 View PostHas anyone had success with the use of the still available Koni shocks (for the 71-80 Camaro) on an Avanti? What ride setting did you set the Konis up with (firm, medium or soft)? I would think the Camaro is a significantly heavier car than the Avanti, at least on the rear axle. Perhaps the front Konis are a good fit ride-wise for the Avanti, due to the heavier Stude V8 engine?
Allen1964 GT Hawk
PSMCDR 2014
PSMCDR 2013
Victoria, Canada
Go here and look for a mid 70's Avanti. They should be all the same as the same Studebaker chassis was used until the early 80's. http://showmetheparts.com/kyb/
Here are some more for research.
http://gabriel.com/product-search/li...Avanti&engine=
http://gabriel.com/wp-content/upload...des_051414.pdf
Also have a look at Bob's site. http://www.studebaker-info.org/rjtec...tml#Suspension Scroll down to Shock Absorbers. Some good reading.
Fronts are easy to find, rears not so easy. I found the 1957 Plymouth Fury in the KYB list and the stroke is not as long as listed for Studebaker rears on another manufactures site but I have had no problems.
Len.
Does the Hawk have a rear sway bar? That will make a BIG difference.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
60V-L6 - 60 Lark convertible
Originally posted by studebaker-R2-4-me View PostI run Koni Shocks in both my '64 Hawk and '63 Lark. Do they feel better?...who knows after installing a 1" front sway bars. I can tell you the sway bars were a big improvement.
Allen
