Ether or Starting Fluid not recommended
  • #31
    Geez Jeff I outta tell ya about a couple of people I spoke to on the Internet who shared a love for making mini cannons!!
    I like using gas myself. Dribble a little down the throat to get a setting engine going. Little word though on whatever easily lightable fluid you guys use; too much fuel a slight leak at the manifold or base gasket, and a hot exhaust manifold can bring real trouble real fast. LOL, dont ask how I know this, but luckily I was able to extinguish the an exhaust manifold fire with rags on a flattie six before it got too out of control. [B)]
    1950 Studebaker 2R5 with 170 turbocharged
    [img=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/DSC00003.jpg?t=1171152673[/img=left]
    [img=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/DSC00009.jpg?t=1171153019[/img=right]
    [img=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/DSC00002.jpg?t=1171153180[/img=left]
    [img=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/DSC00005.jpg?t=1171153370[/img=right]
    • #32
      Saw the tire trick once when I had some bead-lock type HD towing tires that needed re-seating - never seen it before, but kinda freaked me out - worked though.
      As for diesels, I wouldn't use starting fluid. When I used to earn my living as a heavy equipment mechanic, we'd just us a rag soaked in gasoline over the air filter to get a diesel going - might crack the injector nuts if the system had been open, but I'd never run a diesel on starting fluid trying to bleed injectors...YMMV
      If a car has been sitting, I like to fill the bowl through the vent (if it's accessible) so I can get the accelerator pump working. If it's just being cantankerous & doesn't want to start, then the quick-start stuff comes out, but I start very slowly & try to use the least amount possible. A good strong battery helps every time too.
      Daddy always said, if yer gonna be dumb, you gotta be tough & I'm one tough sumbitch!
      Daddy always said, if yer gonna be dumb, you gotta be tough & I\'m one tough sumbiatch!
      • #33
        PLEASE do NOT encourage Jeff! He seems to "f-up" with out our help! BOSEG!
        Jim
        their Memorials!
        • #34
          I ar uh perfeshnul
          Jim
          • #35
            The spud gun thing sure brings back memories. I learned how to make them out of pop cans and duct tape. Where might you ask. The electronic shop of the state highway patrol.
            Denny L
            • #36
              My son raced go-karts for 8 years and WD-40 is all we ever used. The engines ran on methanol and in the winter that stuff don't atomize like gasoline! We would squirt WD-40 down the exhaust header while pulling the crank and the thing would fire right up! The overlap on the valves was enough to pull the WD-40 into the combustion chamber.
              1955 President one owner
              Moncks Corner, SC
