Piston rings
  • #16
    A few years ago total seal rings were a special order and upwards of 400 bucks a set! Thank goodness they have come down.
    Bez Auto Alchemy
    • #17
      Originally posted by starliner62 View Post
      Jack, how much cylinder shrinkage do you see as the block cools from honing?
      Since we're doing custom work and don't push our hone as hard, a Studebaker block typically won't change .001", but it's not a cylindrical shrink. Since the block has reinforcements top and bottom, that doesn't grow and shrink as much. The middle of the bore is thinner and so it grows barrel-shaped and then shrinks back.
      On some of the thin-wall stuff, with the production shops pushing their hone as hard as it will run and not using a torque plate, we've seen some come in .0015" out of round when a torque plate is applied.
      We end up with a block which is straight cylindrical and all eight within .0005" of each other and within the specified clearance.
      jack vines
