Avanti windshield
  • Body / Glass: Avanti windshield
    It seems my glass shop sourced a new windshield for my '63 R2 and when they went to install it they said it was missing the cutout along the bottom for the raised gunsight contour. They will be keeping the car inside thier shop under my car cover until they get the correct glass but they want to know when the cut of the glass changed. I couldn't answer that question. Can someone let me know so I can tell them and get my car back?
    It is full winter here now and I am really reluctant to drive the car home once it is fixed but I guess I will have no choice.
    Thanks
    I don't remember that cut changing on Studebaker Avantis.
    Be sure to use a very good glass shop. In my opinion, Avanti windshields are difficult to install correctly.
      Come' on! difficult?
      64 GT Hawk (K7)
      1970 Avanti (R3)
        By your description your glass shop might have sourced the wrong windshield. They may have purchased a windshield that was used for a 4 door Avanti , this did not have the cutout for the gunsight contour.
        Bob Caser
        mrbobinc
          PHILLIPS CLASSIC AUTO GLASS is the place to go for your Avanti. He has a "business card" ad in almost every TURNING WHEELS & is great to deal with. I get my flat glass cut locally, but all the other stuff came from him. Your installer can order it from him.
            I installed the windshield in my Avanti & wouldn't call it difficult at all. The back glass I had done by a professional. I didn't want to chance it.
            60 Lark convertible V-8 auto
            61 Champ 1/2 ton 4 speed
            62 Champ 3/4 ton auto
            63 G.T. Hawk R-2,4 speed
            63 Avanti (2) R-1 auto
            64 Zip Van
            66 Cruiser V-8 auto
              OK. So I talked with my glass shop and they say they have found the correct glass. It will be a couple of weeks enroute so they are storing the car in their shop under my car cover.
              I had a look at the car with the old windshield removed and it seems somebody used copious amounts of silicone goop to try to seal up a previous installation. What a mess. I have advised the installer about using the proper sealants and techniques when putting in the new windshield. I also left my copy of the Avanti Shop Manual with him. Hopefully he will "read the instructions" before finishing the job. Since I am having the rear window removed and re-sealed at the same time I hope he will heed my advice...
              I know a fellow up here with a 4-door Avanti so I will let him know there is a windshield in town if he needs one.
                The rear is not very difficult, but does require three people to install it.
                Jim Bradley
                Lake Monticello, VA
                '78 Avanti II
                  When I restored my brothers 63, I had a glass co. do the removal and install of the windshield and back glass. Even following the shop manual, and mention to them of possible leak areas, after they were done, it leaks. They redid it this past summer and I don't know the results yet. It hasn't been out in the rain to give it a test. These installers are top notch, and even they have trouble with the Avanti windows. Soooo, if it were me, I'd really stress to your installers the need to make sure the windows don't leak upon completing the install! Good luck and let us know how it turns out, Bill.
                    The windshield on my 1987 Avanti leaked when it was brand new.
                      My three "people" included my then-12-year-old son and his buddy, whom I had sit on the outside of the window as I pulled the string around the inside gasket. It's in there pretty well and is watertight. As you guys know, one must use one's available resources
                        My glass guy installed it by himself! All I did was watch him! But, he's been doing glass work for a very long time!
                        Jim
                        their Memorials!
                          Tom,
                          It's good to hear that SOMETHING went well during your restoration! You've had more than your fair share of gremlins. Actually, when I installed the rear glass in my '63, I had one assistant. We got it in OK, but that is why I suggest three, one inside and one on each side, outside.
                          One tip that I would suggest is to set the glass in place without the gasket and get it exactly centered. With a strip of masking tape on both the bottom of the glass and the body, mark a vertical line. Install the gasket, and align these centering marks. Getting started in the exact center will save a lot of grief when you get to the sides of the glass.
                          Jim Bradley
                          Lake Monticello, VA
                          '78 Avanti II
                            I stopped at the glass shop Friday and they are still waiting on the proper new glass but they have the back glass out and will be re-installing it with the new gasket I supplied to them. The front glass is an insurance thing but the back glass is out of my own pocket.
                            The installer had one comment. "where did they find so much silicone back in 1963?"... It seems both shields were last installed using copious amounts of silicone goop to seal them in. I hope they don't charge too much for removing the mess that was left behind!
                            It looks to me like the person who had the car restored in 1986 or earlier (I have a "certificate" that was supplied with the car that states it was restored in 1986) took it to a shop that had NO IDEA what they were doing when they re-installed the glass. Even the A pillar stainless mouldings were beat up during a previous removal. I have supplied the shop with excellent used replacement mouldings to install and will try my hand at refurbishing the damaged trim some time down the road. I expect to see a night and day difference when the car comes back to me.
                            As for the 4-door windshield that started this thread, if anybody needs one they should contact Crystal Glass in Canada. We all now know where there is one to be found north of the border.
                              Bob Caser
                              Is this a fact? The 1990 still had the asymmetrical "gunsight" bulge on the hood.
                              I am not saying that you are incorrect because I do not know and I am trying to learn. It seems odd to me that they would change the windshield.
                              Which "style" was used for the 1991 convertibles?
