what would you do? 232 or 169?
  • Engine: what would you do? 232 or 169?
    my 52 needs a rebuild i found one of my cyl only has about 10 lbs of compression.
    Now i have a 232 currently stuck supposed to be rebuilt years ago and never ran.
    So do I see if I can save the 232? and use that engine? or redo the 169 and tweak that one out. Would I need a different transmission For the 232?
    Who do I take an stude engine in Minneapolis to get good work from?
    I have a 1950 4 door Commander a 51 land cruiser And a 52 Champion
    I'll Tattoo you anytime!
    And you can find me at....
    New Shop Name Same tattoo shop
    Crazy Lady Ink
    Shakopee Mn.
    952-445-3281
    27 years in the tattooing biz
    Yes, even a 232" V8 is a huge step up from the 169" Champion.
    Yes, you'll need a T86 overdrive transmission.
    jack vines
      On one hand the word..."stuck"...is a scarry word.
      It can be as simple as one stuck pistin ring, to a frozen wrist pin, to a frozen valve.
      Like Jack, most definatly go for the 232. BUT....DO NOT try to "unstick" it with a wrench. If the crank won't turn with about 50ft.lb. worth of turning force, then by ALL means, take the engine apart...
      This way, you'll find the problem and fix it the "correct" way...NOT just by force..!
      In doing this the correct way, you'll also be able to check everything in the engine and make any bad stuff...right...!
      And in doing this...the correct way, it should provide you with top notch service and a fun car to drive.
      Remember, "short cutting" things like this...will only end up biting in the butt on down the road. Do it the right way.
        Ok so a T86 trans what about the rest of the drive train will the rear end be ok and that tiny drive shaft I have?
        Also what cars has the T86?
        how do i identify one?
        Crazy Lady Ink
        Shakopee Mn.
        952-445-3281
          Stick with the six and get it rebuild.
          There is a long list of parts you need to switch.
          That will cost you more than fixing your six.
          Members of the Minnesota crowd can tell you where to take your engine.
          Attend the upcoming meet at Menomonie .
          Join the North Star Chapter
          http://forum.studebakerdriversclub.com/showthread.php?83414-2014-Zone-Meet-Schedule-Information
          Robert Kapteyn
            I have to agree with Bob. If you have not already been contemplating a switch to the V-8, and all the little details involved, you will be better served to overhaul the Six.
              My vote is to fix the six. Converting a Champion to Commander power, requires heavier front suspension, and other modifications that make the project much more involved than bolting in a bigger engine. If you want more power...fix the six, sell it to some one who would like to have it...and use that money (perhaps you'll need a bit more), and buy a V8 Studebaker. It's part of that game in life we all play. Years from now, you too can talk about a Studebaker you "used to own." (Wish you hadn't sold)
                ok ill fix up the 6
                Crazy Lady Ink
                Shakopee Mn.
                952-445-3281
                  Nothing like a V-8.
                    It doesn't matter what it takes... go with the V/8!
                      Originally posted by EssexExport View Post
                      Nothing like a V-8.
                      sals54
                        Unless you want to race it , the six is more than you need for a Sunday drive.
                        Robert Kapteyn
                          I agree with Sal, but it depends on how you would like to use the car, what your budget is, and how important originality is to you. One option is to locate a donor car with a V8. In your neck of the woods you may be able to find a later model V8 car that has rust issues but still has a good drive train. You would then be able able to swap everything you need over to your 52. You can end up with V8 power, heavier duty springs, bigger brakes and a rear axle suited to the V8. That is what I am doing with my '54 wagon, it will have all the underpinnings of a '64 Cruiser when I am done. If you buy right, you can even come out ahead of the game money wise if there are parts from the donor and your '52 that you don't need and can sell.
                          Pat Dilling
                          Olivehurst, CA
                            Everything that has been said about the V8 being the long run "BEST" choice is very true.
                            However I am guessing, that just maybe you are not into heavy wrenching yourself? This will be a Big problem with some of this advice.
                            The cost of PAYING to do a conversion, while worth it in satisfaction down the road many years, will not be a financially responsible choice.
                            Starter List:
                            A complete V8 Engine 232, 259 or 289
                            Clutch housing with all clutch linkage
                            Flywheel, Pressure Plate, Clutch Disc and throwout Brg. in usable cond.
                            Transmission T-86 Short Tail with Overdrive, 1951 to 1957
                            Two Piece V8 Overdrive Driveshaft for correct wheelbase
                            A '49 to '52 Commander V8 Dana 44 Rear Axle with the compatible to engine size axle ratio 3.73, 4.09, 4.56?
                            Commander V8 Front Springs
                            All 4 Wheel Units of '54 to '66 V8 Brakes with Drums.
