Clearance tolerance?
  • Engine: Clearance tolerance?
    In the main and rod bearings my Chilton book calls for .0015 oil clearance. I suppose this is the minimum on assembly? How much is still good allowing for wear?
    Which engine?
      64 259 full flow.
        All the interesting stuff you do and you're using Chilton as your engine building reference? C'mon, spring for a copy of the Studebaker Shop Manual - .0005"-.0025" mains and .0005"-.002" on the rods.
        FWIW, an engine worn to the upper limits is going to have lower hot oil pressure than I like to see.
        jack vines
          It's interesting to me that Chilton's survived and MOTORS did not. MOTORS is the best by far, IMO and Chilton's is riddled with mistakes. Although the older Chilton's had lots of cool short cut tips.
          60V-L6 - 60 Lark convertible
            As Jack says, the Stude "book" sounds like the one to follow.
            Though .0005" sounds a "tad" too tight, the .0025"/.002" is more higher rpm, race clearance.
            While all above will work, something in the .0015 to .002" (rod and main) range sounds great to me.
            And as Jack notes, looser clearances will give slightly lower oil pressure shown on the gage, but it' should only be a couple of pounds, nothing to worry about.
              jack vines
              You callin' me a CASO? Guilty.
              Actually I am just trying to sell some parts and wanted to figure out how worn they are. For actual rebuilding and such I rely on my best friend who owns the best automotive machine shop around these parts.
                Thanks Mike. Although overly simplified perhaps the Chilton's was right in the middle of the tolerances I see being bandied around here, if I understand it correctly.
                  I only make this a point because my high school shop instructor always did (and so in Mr. Pohl's honor):
                  Clearance is the designed (intentional) difference between parts.
                  Tolerance is the difference between ideal and acceptable.
                    You know now that you mention it I believe I did hear that in shop class too!
