Which Clutch and Pressure Plate?
  • #16
    So we are asking exactly the SAME thing Joe, what Pressure does this AMC Jeep pressure Plate actually have? Said in one relatively short sentence.
    • #17
      I got a call back from AMS this morning. The AMS 01-505 pressure plate has 12 springs and is 1800 lbs. so its nearly identical to the R1/R2 part. I hope to get it installed in the next week. I'll report back on how it works.
      • #18
        That sounds like it would be a good H.D. Replacement for Larks/Hawks and a perfect replacement for Jet Thrust and Avanti Engines. The only thing we have not yet determined is if the Clutch Disc. Hub is a 10 Spline like most, but since I think most older Jeeps had Borg Warner transmissions it SHOULD be good.
        Thanks a lot for the 01-505 Part Number, most of us with 289's or "faster" 259's should be able to order one if yours works good. Definitely Machine the Flywheel and get a New Stude. Throw out Brg.
        UPDATE: I just enlarged their Pic and counted 10 Splines!
        • #19
          I have found a reman Borg & Beck, 10 1/2" with 9 springs (red) + 3 empties, anybody know if it is HD or Std? I cannot get any specs from the seller (he doesn't know), reman was KPC CA1588. Comments please.
          • #20
            Nine springs is going to be very near Std. = 1456 Lbs.
            That CA1588 is a Borg & Beck Number, why not research it?
            So you have not ordered this one YET?
            http://www.amsautomotive.com/AMS/Tem...8&KITID=01-505
            • #21
              CA-1588 is a 10.5 inch B & B style, listed only for H.D. 1962-64 Chevrolet applications, 2235 lbs. Probably a little strong for casual everyday street driving.
              This information from my 1983 Rayloc remanufactured clutch assembly catalog - lots of great info in it!
              • #22
                Jerry, Thanks for that info.
                • #23
                  I ended up getting the AMS 01-505 clutch and pressure plate installed this summer. I was able to put a few hundred miles on it before I put it away for the winter.
                  I can report that its a direct bolt in replacement. The clutch works great and the pedal pressure is similar to a standard stock clutch. The adjustment was a little long, but I switched to an Avanti rod which is longer.
                  • #24
                    I know this is an old thread, but I called AMS and the AMS 10-505 is no longer available. The tech guy said the recommended replacement would be AMS 01-026A. This is a diaphragm type pressure plate 2100 #. Do not know if the throwout bearing will work. A search indicates it is available at various retailers.
