Rear Brake Hose
  • Rear Brake Hose
    I am having difficulty finding a rear brake hose for my 56 Powerhawk.
    Will the front hose Raybestos BN11149(front) also work in the rear or is it too short?
    Too short, I found the interchange with Google last time I needed it.
    JDP/Maryland
    64 R2 GT cost to date $55046.57
    64 Daytona HT/R2 clone
    63 Lark 2 door
    58 Packard HT
    56 Golden Hawk
    52 Starliner
    51 Commander
    39 Coupe express
    39 Coupe express (rod)
    JDP Maryland
      Check the interchange on my web site, there are two different lengths possible for a '56 rear hose, and some of the numbers I have listed are unconfirmed (so let me know if you use one and it works for you.)
        I have bought hoses from this guy...
        http://cgi.ebay.com/ebaymotors/67-68...spagenameZWDVW
        ...and they are first class. Quite reasonable even with the shipping.
        He can make anything and they are spot on.
        Bellingham, WA
          I must correct one screw up not to miss lead. The tee end is not inverted flair straight 3/8-24 thread with copper washer so the
          advance hose sounds right.
            If you have access to an advance auto or related. They list hose for 56 hawk. doesn,t state if for front or rear. length indicates rear. Part #H11146- Spec are 18.00 length. 3/8-24 thread, male one end, female other. If your unaware this are 3/16 inverted flare ends. The steel line end is 3/16 and I,m reasonably certain the male end that goes in the tee is the same.(the steel line will thread in where you removed hose if I,m correct) Don,t have fitting handy and brain old and foggy. If you have a NAPA near with someone who knows what their doing or gives a damm to help you (good luck) their catalog lists hose by length and ends with photos. They should be able to help you find one that will work. I use their books here locally for things like this.
              The 18 inch hose you list is just fine, maybe 1/2 longer then factory, but way better then the 14 1/2 I've seen used. The short hose will work until you put the rear up on jack stands on the frame, then the hose will end up supporting the weight of the hanging rear end.
              JDP/Maryland
              63 Lark 2 door
              58 Packard HT
              56 Golden Hawk
              52 Starliner
              51 Commander
              39 Coupe express
              JDP Maryland
                Thanks Dick
                This Argentine supplier lists a set for the Goldenhawk
                http://cgi.ebay.com/ebaymotors/56-57...QQcmdZViewItem
                Anyone know if hoses for a Powerhawk would be different?
                  I don't know if it makes a difference to you, but the Argentine hoses are not US D.O.T. approved like the vendors hoses. I told Dennis at SASCO about him possibly using the Argentine hoses, but he passed due to liability issues. For items like brake hoses, I'll spend the very few extra bucks.
                  JDP/Maryland
                  63 Lark 2 door
                  58 Packard HT
                  56 Golden Hawk
                  52 Starliner
                  51 Commander
                  39 Coupe express
                  JDP Maryland
                    If worse comes to worse, use a rear hose for a 77 Dodge D150 truck. You'll have to bend the existing brake line a bit, but otherwise it works.
                      How could you bend the brake line since it has to fit in the rear bracket and clip ?
                      JDP/Maryland
                      63 Lark 2 door
                      58 Packard HT
                      56 Golden Hawk
                      52 Starliner
                      51 Commander
                      39 Coupe express
                      JDP Maryland
                        Don,t vendors have these or just you can order the Hose from Advance on line if necessary.
                          I have no problem finding them locally and yes, all the vendors stock them.
                          JDP/Maryland
                          63 Lark 2 door
                          58 Packard HT
                          56 Golden Hawk
                          52 Starliner
                          51 Commander
                          39 Coupe express
                          JDP Maryland
                            azopelnut; you gotta stop shopping for your Stude. parts at the Honda dealer!
                            All of the Stude. vendors stock these, and every parts store I've ever gone to, lists and orders these from Raybestos if you want to pay their price! Och!
                            Studebakers Northwest
                            Ferndale, WA
                              Now that I think about it, doesn't Turner sell these in stainless/teflon? If you feel like spending money, it's a nice upgrade (firmer pedal)
