My battery goes flat if I leave it connected. I've checked for current through lamps, fuses, etc., but haven't been able to pinpoint the cause of the drain. So, I now disconnect the battery every time I put the car away.
I'm now wondering if my heat indicator (water temperature sender) could be the culprit. Any thoughts on this? (BTW, coolant is smoking off the top rear of the driver's side valve cover; so I'm hoping that replacing the heat indicator might cure both problems.)
