what type of rad cap to use & is it a pressurized system
  • Cool/Heat: what type of rad cap to use & is it a pressurized system
    Bought a cap for a non pressurized system from S.I. for my 50, but seems like it's building pressure & leaking out of the overflow, Looked in the shop manual didn't see anything on coolant pressure
    How much are you filling it? There should be about one inch of space between the bottom of the filler neck and the water.
    Terry
      Many Studebaker cars were unpressurized up to around 51 or so, but the radiators will accept a pressurized cap. I always use about a 5 pound cap and you can get them from the major Studebaker vendors.
      Don't use anything more than 7 pounds, as you might start to spring leaks.
      I do not know how the radiators and heater cores were built in 1950, nor how many pounds of pressure they were made to withstand, but I do know that 5 pounds is not too much for them.
      60V-L6 - 60 Lark convertible
        Be sure you use a cap that matches the depth of the radiator neck. like RadioRoy said, use a 4 or 5#. It's gonna push out a little.
          Agree w/ all above. The "old school" radiator shop that re-cored the '63's unit stated that the older radiators, esp. those w/ large upper tanks, were not designed for more than 5 - 7 psi. One of the several Stude' parts vendors, can supply one.
          Paul TK
