Aside from SI, does anyone have experience with replacement antennas that look original? I see some on eBay, but it's hard to tell how well they fit since they are pretty much advertised for everything. Does anyone have a brand and part number for an antenna I could get through NAPA or some other local source? Or, does anyone have an original for sale? I have a 66 Cruiser. Thanks.
Replacement antenna for 64-66
All the ones I've seen are the generic type that will not work in the same position as the original Stude antenna. I wish someone would make a reproduction of the original antenna, I'd take at least 6!!59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
[QUOTE=Warren Webb;845670]All the ones I've seen are the generic type that will not work in the same position as the original Stude antenna. QUOTE]
Would you elaborate on that, please?
I use the ones that manually go all the way down, so you can put on a car cover. They have a shorter mast than original, more sections, plus they are brushed instead of shiny chrome. But they are the best I have found, simply because they go all the way down. Having said that, I have not found that they would not fit in original holes. The mounting hardware does not look original, either, but they still can be mounted in the original holes.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
All the generic ones I've seen mount directly under the fender so on the original Stude position there isn't enough room between the fender & cowl for that mount. the original Stude manual antenna had a "washer like" stack on the upper portion of the mast base that went up against the inside of the "A" pillar location so that the retaining nut & base sandwiched the mast on the (topside) outer portion of the left front fender. If you have access to an antenna that works I'd like to see it. Mounting hardware not looking original would not be a concern to me.59 Lark wagon, now V-8, H.D. auto!
64 Zip Van
66 Cruiser V-8 auto
Originally posted by Warren Webb View PostAll the generic ones I've seen mount directly under the fender so on the original Stude position there isn't enough room between the fender & cowl for that mount. the original Stude manual antenna had a "washer like" stack on the upper portion of the mast base that went up against the inside of the "A" pillar location so that the retaining nut & base sandwiched the mast on the (topside) outer portion of the left front fender. If you have access to an antenna that works I'd like to see it. Mounting hardware not looking original would not be a concern to me.
I have one that you can turn the the know up and down from inside the car cab. It is in perfect condition. Let me know. Also, for all you stude members, I rebuild stude antenna that were used from 1947 to 1958. Let me know if you need yours rebuilt.
Originally posted by Scott View PostAside from SI, does anyone have experience with replacement antennas that look original? I see some on eBay, but it's hard to tell how well they fit since they are pretty much advertised for everything. Does anyone have a brand and part number for an antenna I could get through NAPA or some other local source? Or, does anyone have an original for sale? I have a 66 Cruiser. Thanks.
Chris
STUDEBAKER of AUSTRALIA
www.studeparts.com.au
