Installed a replacement straight line ball-type heater control valve. Bought new from SI. Works well for the heat control, however, seems it should be secured to something. Currently it is suspended by the hoses (elbow and straight) and resists being opened by pushing in the control knob on the dash. Knob will pull out to close the valve, but will not go back in to open it. Opening is currently by hand under the hood, not something for long term use.
Heater Control Valve
Tags: None
Originally posted by GTCruiser View Post...seems it should be secured to something.Brad Johnson,
'56 Sky Hawk in process
I don't mess with replacement valves or NOS. I've had Joe Hudacek in WI. rebuild my valves. He advertises in Hemmings and does excellent work. The valve comes back looking better than NOS. I don't mean to knock anyone but I don't do conversions. I'm more into originality and want things to work the way they were intended even if it was 50 years ago!
Rob in PA.
Can you secure the sheathing of the cable at the valve end? If the sheathing is attached to both the valve and the dash board, it should work in both directions.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Originally posted by RadioRoy View PostCan you secure the sheathing of the cable at the valve end? If the sheathing is attached to both the valve and the dash board, it should work in both directions.
Originally posted by stude1964 View PostI don't mess with replacement valves or NOS. I've had Joe Hudacek in WI. rebuild my valves. He advertises in Hemmings and does excellent work. The valve comes back looking better than NOS. I don't mean to knock anyone but I don't do conversions. I'm more into originality and want things to work the way they were intended even if it was 50 years ago!
Rob in PA.Ed Sallia
Dundee, OR
Sol Lucet Omnibus
Forgive my stupid question/statements. I have a 63 Lark Regal with a heater problem. The heater seems to be on all the time, even with the fan and heater/defroster off, etc. Since it got quite warm inside the car, I thought it might be overheating. The radiator was checked out and found to be in excellent condition by an old time radiator shop. They said it had be recored and worked fine. So, I figured it was some sort of a thermostat problem with the Climatizer, because I finally traced the warmth to the heater itself being on, radiating heat so to speak. Since I never drive the car when it needs heat or defrosting, I though I would just bypass the system by looping the heater hoses under the hood. Not the ideal, but the simplest and cheapest! Then when I read this Thread, it sounds like it could be a Heater Control Valve. Any expert opinions to help this non-mechanic? Thanks in advance.Last edited by sochocki; 05-21-2014, 01:03 PM.
sochocki - I believe that may indeed be your problem. When the control valve gets worn it may not close all the way and will let coolant bypass through and into the heater core. Replacing or rebuilding the control valve should solve the problem. They get old like us and leak. Ha ha.Ed Sallia
Dundee, OR
Sol Lucet Omnibus
Originally posted by GTCruiser View PostEstablishing a point to secure the sheathing near the valve is the challenge. Maybe someone has done that before and would have advice. Did find the sheathing is not secured under the dash, which should be more easily corrected. Thanks
But securing the sheathing to the dash would be the first step and may even be enough to do the job.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Another stupid question. Regarding my 63 Lark Regal (259 V8) and its misbehaving heater control valve. The car is in storage now still, so I checked my shop manual to see if I could tell the location of the HCV. I guess I am learning disabled, but I could not tell from the text and diagrams exactly where this elusive valve is. I seem to remember a thermostat-looking object underneath the dash, on the far right side of the climatizer, close to the bottom of the instrument panel. Or is this under the hood, near the heater core?? Sorry for the ignorance!!
