61 Lark Grill Fit a 60??
  • Body: 61 Lark Grill Fit a 60??
    Hi, does anyone know if the grill insert from a 61 Lark will fit a 60 Lark??
    Dale Wendorff
    Hudson, WI
    60 Lark Convertible
    55 Champion coupe
    There still seem to be lots of NOS '60 grills out there if that is what you need. Think '61s are a little harder to find. '59 grill mesh is just about NLA. If I am wrong, someone will chime in.
    Good luck.
      No...the 61 grill will not fit a 60 Lark.
      A while back I bought one (NOS) "thinking" the same thing. The 59 and 60 are the same. The 61 is just a little larger, in all directions.
ID:	1688684 Click image for larger version
Name:	Deluxe Six 2 Door1.jpg
        Mike is right, if you look at both Cars you will see that '59 & '60 Have Parking Light/Air Vents between the Grille and head Lights, so the much wider '61 Grille would not fit in the Front Panel.
        The Two small Parking Lights & Hd. Lt. or Optional on Deluxes, Four Headlight system is not as large as the '59-'60 setup allowing a wider Grille on '61's.
        The '59 Grille Mesh has been NLA since about 1961 and superseded to 1960!
          Unless someone like myself decides to make one available someday...........
