Need your Help / Advice
There are welded tabs that are broken on the rear two bearing caps that are the ones captured by the C-Clamp to the yoke. I can find no corresponding weld points.
1) Front U-Joint has a grease fitting and rear does not?
2) Rear U-Joint has a previously cut welded tab on the 2 bearing caps that are captured by the c-clamp. What are these welded tabs?
Thoughts,
Jim
Thoughts,
Jim
