On my 62 Lark project, the car came with a "new" gas tank. I've had the car 3 years, and most of the time there has been some gas in the tank. Looking in thru the hole for the sender I can see some rust in the lowest parts of the little valleys of the bottom of the tank. The exterior of the tank looks new, and the inside does too except for the rust.
I want to remove the rust and I was thinking of removing the tank and using a product called Evaporust. I've used this on parts and it works great. My questions is what to do after I remove the rust? I've read both good and bad reviews of Eastwood''s tank sealer kit, with some claiming the sealer peels off in sheets and plugs everything up. If I just clean it and refill it, is there something I can add to the gas to prevent rust from forming again?
Any thoughts on the best way to correct this? As I said, the rust is very minor. I just want it out of there and I don't want it to return. Thanks
