51 Champ new tires - rims
  • 51 Champ new tires - rims
    It it time to find some paws for the 51 and as we expect only to drive the car locally, we want to do so as inexpensively as possible. So here is my question. The car had 6.4X15 bias tires on it from the factory.
    What size would that be in a radial tire[?][?]
    Can you buy bias tires as cheap as modern radials[?][?]
    Will the riveted rims hold air using radials without tubes[?][?]
    If not, can you run tubes in radial tires[?][?]
    Did the G10 W3 come with black sidewall tires[?][?]
    Were wide white walls sold as on option with the full rim hubcaps[?][?]
    Regards,
    Jerry
    Here is the Coker Tire link to your size tires
    http://store.coker.com/search.php?mo...bstring=640-15
    And here is their conversion chart
    http://store.coker.com/pages.php?pageid=18
    All Studebakers came standard with blackwall tires. Whitewalls and full wheel covers were an option.
    Leonard Shepherd
    http://leonardshepherd.com/
      quote:Can you buy bias tires as cheap as modern radials
      With a few exceptions, No. And, unless you are looking for points in a car show, you don't want bias anyway. Radials are safer, more stable and more comfortable.
      quote:Will the riveted rims hold air using radials without tubes
      Yes.
      quote:If not, can you run tubes in radial tires
      No.
      '33 Rockne 10,
      '51 Commander Starlight,
      '56 Sky Hawk
        No; the white wall tires and the full wheel covers were SEPARATE options. You could have either one with or without the other! [:0]
        Most people end up with P205X75R15 since the 195's are no longer made in most styles and brands of tires.
        The stock wheels were 5 in. wide & able to handle the 205 radials just fine, if their condition is not good, it will be difficult to find 5 or 5 1/2 in. wide 15 in. rims with 5 on 4 1/2 in. bolt pattern to fit the tires and car.
        Studebakers Northwest
        Ferndale, WA
