Distributor vacuum port
  • Distributor vacuum port
    I'm installing an Edelbrock 500 on my '62 Hawk 289. I need to determine if the distributor vacuum port is timed (no vacuum at idle) or full (vacuum present at idle). I have already removed the carb and thought the answer was in my manual but I can't find it. Reading between the lines from some manual distributor info I would guess vacuum is present at idle.
    Regards,
    John
    John Esmonde
    Holland Landing, Ontario
    Canada
    '62 Hawk
    '30 Chev Coach
    sigpicJohn Esmonde
    Canada
    \'62 Hawk
    \'60 Lark Regal Convertible
    \'30 Chev Coach
    I am not sure about the Edelbrock clone, but the Carter AFB on my 259 has a vacuum port on the left (as facing the carb) that is higher and has no vacuum at idle, and a port on the right that does have vacuum at idle. (The PCV port is in the center.) I have the left port plumbed to the vacuum advance.
    jj
      jj is correct,and it is the same on the new Edelbrock.
      Dan Miller
        Passenger side port is correct...
        64 GT Hawk (K7)
        1970 Avanti (R3)
          Yup- passenger side on the new edelbrock.
          Ross.
          Riverside, Ca.
          1957 Provincial X2
          1958 Transtar
          1963 Lark. F.S.
          Ross.
          Riverside, Ca.
          1957 Provincial X2
          1958 Transtar
            Again, thanks to all. The carb is installed and car running great.
            Regards,
            John
            John Esmonde
            Canada
            '62 Hawk
            '30 Chev Coach
            sigpicJohn Esmonde
            Canada
            \'62 Hawk
            \'30 Chev Coach
