Hello all . Getting ready to tackle a oil pan gasket replace on my 55 champion . Should I be able to get pan off without pulling the engine ?
oil pan gasket
SN-60 I was just about counting on having to lift the engine a little . I was really hoping to be able to put it on the lift and do it all from underneath. but I also have a rig that I made up for fwd cars that lays across the engine bay and I can lift the engine and still be able to do it from under.
Originally posted by longtops View PostSN-60 I was just about counting on having to lift the engine a little . I was really hoping to be able to put it on the lift and do it all from underneath. but I also have a rig that I made up for fwd cars that lays across the engine bay and I can lift the engine and still be able to do it from under.
Hey, if you get doing it I'd love to see some pictures of what I am in for. I have a 55 Champion as well and have the oil pan gaskets on route. I really need to clean the old oil and crap out of there so my plan was to remove the pan. I didn't realize how much of a production it was. And I do have the shop manual en route.
Did this a long time a go (55 Champion cpe. 6 cyl./std. V/8 MAY NEED TO DROP/REMOVE EXH. CROSS OVER?? I didn't have all the luxury of a lift or jack stands(b/jack&blocks) Didn't loosen/raise eng. .Anyway: LIFT COMP. FRONT END HIGH ENOUGH FOR EASY ACCESS TO WORK & SECURELY SUPPORT OF COURSE . Turning wheels as suggested will give a little more wiggle room to drop pan down. I don't recall any obstructions . Take your time when moving pan away from eng.You may have to juggle a certain way to clear oil sump , tie rod &such.REMEMBER WHICH WAY FOR EASE IN RE-INSTALL(much less struggle)!!TIP: APPLY SEALER TO PAN- SECURE GASKET TO PAN WITH LIGHT THREAD THROUGH BOLT HOLES FRT/MID/ RR BOTH SIDES(SAVES GSKT FROM MOVING-EASIER TO ALIGN/INSTALL BOLTS). APPLY SEALER TO BLOCK /INSTALL PAN ALL BOLTS LOOSE. SO YOU CAN CUT/REMOVE THREAD BEFORE TIGHTENING BOLTS EVENLY FROM -MIDDLE- OF PAN.ALTERNATING SIDES&DIRECTION-FRT TO REAR ("TORQNG. TO EVENLY SEAL GSKT.") NO LEAKS
Originally posted by arthurc1946 View PostDid this a long time a go (55 Champion cpe. 6 cyl./std. V/8 MAY NEED TO DROP/REMOVE EXH. CROSS OVER?? I didn't have all the luxury of a lift or jack stands(b/jack&blocks) Didn't loosen/raise eng. .Anyway: LIFT COMP. FRONT END HIGH ENOUGH FOR EASY ACCESS TO WORK & SECURELY SUPPORT OF COURSE . Turning wheels as suggested will give a little more wiggle room to drop pan down. I don't recall any obstructions . Take your time when moving pan away from eng.You may have to juggle a certain way to clear oil sump , tie rod &such.REMEMBER WHICH WAY FOR EASE IN RE-INSTALL(much less struggle)!!TIP: APPLY SEALER TO PAN- SECURE GASKET TO PAN WITH LIGHT THREAD THROUGH BOLT HOLES FRT/MID/ RR BOTH SIDES(SAVES GSKT FROM MOVING-EASIER TO ALIGN/INSTALL BOLTS). APPLY SEALER TO BLOCK /INSTALL PAN ALL BOLTS LOOSE. SO YOU CAN CUT/REMOVE THREAD BEFORE TIGHTENING BOLTS EVENLY FROM -MIDDLE- OF PAN.ALTERNATING SIDES&DIRECTION-FRT TO REAR ("TORQNG. TO EVENLY SEAL GSKT.") NO LEAKS
When you have the pan off ,replace the rear main oil seal.
I siock these N.O.S. at $20.00 postpaid.
Robert Kapteyn
studebaker@mac.com
