I tend to agree with one of the earlier comments that it will function fine on 12 volts. You should certainly get full extension of the small spring that runs the clock meaning the clock solenoid will need to operate less frequently.
If you are concerned with the higher voltage simply measure the clock resistance to ground at the power input. (Power off and clock run down to assure points are closed.) You could then put in a line resistor approximately equal to the resistance of the clock, preferably a little smaller value. This circuit dissipates very little power as the points are closed less than 1/10 of a second once every few minutes so a huge wattage resistor is an overkill. A half watt resistor would be more than sufficient.
I would avoid exotic designs. Chances are too high that doing the fix will break something else.
