No Brake Lights
  • #16
    No, that indicates there is power to the stop Light switch and the Fuse IS Good! BUT! You said this:
    "The dome light DID work before the short, as a matter of fact it stayed on all the time...had to remove the bulb."
    That leads one to believe that the Dome Light is now having No power.
    As I explained in Post #9, they are on the same Fuse.
    As you were told in Post # 10, "THE STOP LIGHT SWITCH IS BAD". About the only other option is the Female Wire Terminals at the Switch are not clean or too loose.
    I would think after 24 days of this, the problem would be fixed, no?
    • #17
      Thanks for your kind consideration.
