GM power steering pump
  • Steering: GM power steering pump
    Will a generic GM P/S pump work with Studebaker power steering?
    Mark Riesch
    New Bern, NC
    It does on the Avanti II's, both my 74 and 83 have essentially the same GM pump from that era. The position/bend of the return tube is critical on the Avanti. You'll just need to see how much room you have behind your location. Rebuilts are dang cheap also.
    Bob
      "GM" Saginaw P/S pump (resembles a canned ham) also found on: 1972/79 FoMoCo Passenger Cars with Hydro-Boost, 1975/91 Econolines.
        GM pumps were even used in ca. 1984 Nissan Maximas as well as some later RWD Torsion bar Mopar cars.
          Does the above apply to both Saginaw as well as Bendix systems?
          Do we know which one the OP has?
          60V-L6 - 60 Lark convertible
            I put a gm pump on a lark with ps no problems worked great
              Well, look at it this way, even the original Bendix system used a pump from a different manufacturer (Eaton).
              Bez Auto Alchemy
                My 66 Cruiser has a GM pump so Studebaker didn't have a problem with it powering the Bendix system.
                60 Lark convertible V-8 auto
                61 Champ 1/2 ton 4 speed
                62 Champ 3/4 ton auto
                63 G.T. Hawk R-2,4 speed
                63 Avanti (2) R-1 auto
                64 Zip Van
                66 Cruiser V-8 auto
                  So how would you modify the stock Studebaker bracket(s) to accept a Saginaw pump? For example, the Eaton pump is bolted to the pump bracket (1964 ohv six) by two bolts at the upper right of the pump similarly to a Falcon or Mustang six. The V8s with the stock Eaton have different bracketry.
                  Jeff T.
                  \"I\'m getting nowhere as fast as I can\"
                  The Replacements.
                    Just to be on the safe side, I'd recommend asking someone with an Avanti II to measure the pulleys on the crank and the pump, just to stay close to the "factory" pump speed. I'd check for you, but I no longer have a II.
                      Precisely. jimmijim
