1951 Steering Column Manual VS. Automatic
  • Steering: 1951 Steering Column Manual VS. Automatic
    Hello, I have an odd question concerning the steering column assembly use in the 1951 models. More specifically, I have a 1951 Land Cruiser that has the automatic transmission in it. I recently came upon a 1951 4-door champion that happens to have the rare OEM turn signal control assembly that mounted directly into the steering column.
    The question:
    Aside from the obvious (Gear Selector indicator for the automatic) what is the difference between the column for a manual shift and one for an automatic in terms of diameter? In other words, will a OEM turn signal control work on an automatic steering column that was originally on a manual steering column. It almost looks like it would, but I wanted to see if anyone knew for sure.
    Thank you,
    Brian
    1947 Studebaker M-5
    1946 Studebaker M-5
    1948 Studebaker Land Cruiser
    1961 Studebaker Lark 4-dr. Sedan
    1951 Studebaker Land Cruiser
    51 on should work. 50 and before they were different between the Commanders, and champions
    Edit: I should say 51 and 52 should work.....53 on all went to the smaller yet column that looks like all of them till the end. Of course there is a steering wheel and column shaft size change in 57 that makes the upper bearing and housing different. And there were several different types of turn signal switches later on too.
    Bez Auto Alchemy
      There should be 2 phillips screws that hold the turn signal housing on the column. BUT! Look inside the column, I'm pretty sure there is a wire ring on the steering shaft that will cancel the signals. I have the signals on my 52, but they do not cancel buy themselves.
      Jim
      their Memorials!
