yesterday I spent 3hrs in a -19C garage cutting through one bolt in order to remove the front of my driver's side leaf spring...I went through 6 sawzall (18tpi metal-cutting blades) (not cheap junk ones either). I think I invented some new swear words. What are the sleeves made of, kryptonite??? Anyone else have as much fun as me? Any alternative means of removing the through bolt when they are rusted so badly to the sleeve that the sleeve rotates in the rubber of the bushing? Don't want to spent 3 hrs. on the passenger side. not happy, and exhausted...junior
cutting rear spring bushing inner sleeves...
Tags: None
Try SawZall brand blades called 'The Torch'...
Awesome blades.... Made for this kind of work....
I swear by them...
I took my 51 to a professional mechanic back in 74 and he could not change them. I'd love to find out a method.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
60V-L6 - 60 Lark convertible
You mean to say you haven't fixed that in 39+ years!?!?
Originally posted by RadioRoy View PostI took my 51 to a professional mechanic back in 74 and he could not change them. I'd love to find out a method.HTIH (Hope The Info Helps)
Originally posted by DEEPNHOCK View PostTry SawZall brand blades called 'The Torch'...
I swear by them...
1954 C5 Hamilton car.
Originally posted by DEEPNHOCK View PostYou mean to say you haven't fixed that in 39+ years!?!?Last edited by RadioRoy; 12-11-2013, 04:29 PM.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Junior, I took the front spring bushings out of a '59 frame back in October, and the trick was to first tighten the through bolt as far as I dared. That seems to break the rust bond between the bolt and the inner sleeve. Once I loosened the nuts, the bolts came right out, no problem. And this was an old field car, not a nice driver. And on the rear shackle bolts, I failed to do that, and every one needed the torch.
Tighten first.Gord Richmond, within Weasel range of the Alberta Badlands
Lots of people here (and gone) addressed their methods in 2007. I thought it sounded familiar and here is the search result.
http://forum.studebakerdriversclub.c...g-bushings-outsigpic
Lark Parker --Just an innocent possum strolling down life's highway.
I used a sawzall to cut the ones on my 54 Conestoga. I also went through a few blades. As mentioned I ran the sawzall on a medium-low speed and moved the blade in and out so it was not always cutting on the same place on the blade. I also cut some, then turned the bolt about 30 degrees then cut more, and so on. That way as the cut got deeper it would be cutting a thinner piece of metal. Took me about 20 minutes a side. I was working in 70 degree F which is certainly more comfortable than you were. I admire your gumption to tackle this in such cold weather. I whine when it is in the 30s F here.Pat Dilling
Olivehurst, CA
Just finished removing the two 7/8" bushings from the rear of the frame using 7/16-20 threaded rod and coupling nuts. The process is slow and I had to stop a couple of times to straighten the rod. It's important to keep the "pusher" square to the frame bore. A tip is to trim the excess rubber extending from the bushing with a razor blade before beginning, as the bushing rubber will be collapsed and tend to put the "pusher" off center. The '64 Daytona has ample room outboard of the frame to allow a 9" rod length. It wasn't necessary to remove the fuel tank or lower the exhaust pipe. With my "advanced" age, it was necessary to use a 24" bar on the socket. Now to reverse the process!
Originally posted by stude1964 View PostI usually burn mine out. A little smokey but doesn't take all day although if it's 19 degrees out it might take the edge off!
Rob in PA.sigpic
