Starter ID
  • Starter ID
    I have three Stude starters -- three different housings or end pieces. The powder coated one fits a 4 sp bellhousing. No tag. 10 7/8" long Can anyone help with what the other two fit?
    middle one is 11" long and has a 2 3/4" end but is shaped different than the top one. the tag says autolite MDU 7026 11S
    Top one is 12" long and it's tag says MDU 7005 11S
    http://i84.photobucket.com/albums/k2...3/DSCN0421.jpg
    64 Champ long bed V8
    53 Hudson Super Wasp Coupe
    MDU is a four field starter
    used on the R series motors. The MDY is a two field starter used on most
    all other V-8s
    automatic - manual
    MDU 7026, MDU 7025
    No data on a MDU 7005 ?
    Studebaker On The Net
    http://stude.com
    Studebaker News Group
    Arnold Md.
    65 Sports Sedan(sold)
    64 Daytona HT
    63 R2 4 speed GT Hawk
    63 GT Hawk
    63 Avanti R1/AC
    63 Avanti R2/4 speed
    63 Daytona HT
    63 Lark 2 dr.
    62 Lark 2 door
    62 GT(parts car)
    60 Lark convert
    60 Hawk
    52 Starliner(sold)
    51 Commander
    JDP Maryland
      The 7005 is for 6cylinder cars.
      Miscreant adrift in
      the BerStuda Triangle!!
        No wonder I could not ID it. BTW, don't count on the tag for ID since the AT nose is often swapped for the stick shift.
        http://stude.com
        Arnold Md.
        64 Daytona HT
        63 GT Hawk
        63 Avanti R1/AC
        63 Daytona HT
        63 Lark 2 dr.
        62 Lark 2 door
        62 GT(parts car)
        60 Lark convert
        60 Hawk
        52 Starliner(sold)
        51 Commander
        JDP Maryland
          Thanks, that was a big help, now I can tag these with the right ID and put them on the shelf.
          question-- why swap the auto for the manuel snout? I know I'm missing something here.
            The snout would be changed for one application or the other - auto or manual. Basically, the distance back that the mount flange is from the tip of the snout is what accomodates the difference of distance of the ring gear on a torque convertor vs a flywheel. The ring gear on a flywheel is relatively close to the rear of the engine whereas the ring gear on a torque convertor sits further away from the rear of the engine and the longer "snout" allows the starter's bendix gear to reach that more distant ring gear.
            Miscreant adrift in
              Right, what he said. The starters are apparently identical other than the snout casting, so if you say are converting from an auto to a stickshift, you don't have to buy a a whole new starter, just find the correct snout and swap it on to your existing starter. I actually just did this with the MDU 7026 on my car, works fine.
