Window won't roll up all the way
  • Body / Glass: Window won't roll up all the way
    My drivers window won't roll up all the way. I have a 54 Commander 4-door, & just replaced the slide the window rides in and glass. The front goes up almost all the way up but the back is sloped downward and is 3/8 in short of the channel at the top when the window is rolled up. Was my glass cut wrong, or is there an angle adjustment that can be made to align the glass in the channel? It seems even when rolled down, and the bottom stop is set OK. There is a 1/2 in nut in a separate hole I played with a bit, but it did not seem to do anything. Does it matter where the glass is positioned in the track that connects to the regulator? I just centered it on the glass.
    Morris Van Horne
    1954 Commander
    did you have the origional glass as a pattern when the new piece was cut ?
    Joseph R. Zeiger
      No- it came from a pattern at a glass shop- wonder if they may have used a coupe pattern.
      Morris Van Horne
      1954 Commander
        The coupe window is much longer than the sedan, so that's not it.
        How does the glass shape compare to the passenger side at similar heights?
        60V-L6 - 60 Lark convertible
          I was hoping to not go there, but may have to pull the passenger side to compare them. The passenger side could probably stand lubing up.
          Morris Van Horne
          1954 Commander
            Verify that the guide pins (that ride in the slots on the bottom of the glass) is really in the slot, not below or above it (front and back)
              I am not suggesting pulling the other side apart. Just roll both of them up to similar heights and see if the tops of both glasses are the same contour, the same relative height from front to back, and things like that.
              The most likely thing is that the regulator is sticking, the glass is cocked, or the glass is not attached to the regulator properly, or the little wheels/guides are broken, or something like that. Just use the good side as a reference and go from there.
              Roll both all the way down and count the number of turns of the crank to the top. Exercise both windows and see what is different from side to side. See if they both go down the same way and to the same depth.
              Roll them both up and compare the relative positions of the bottom of the glasses where they meet the metal part that holds the glass.
              Look at it, measure it, and think about it, before taking it apart. Use the right side as a guide to determine what is wrong with the left side.
                Thanks for the advice. I used a thin piece of cardboard and slid it down between the glass & cat whiskers on both windows. The distances were both the same, front vs front and rear of the window vs rear. I'll take it apart next weekend and do more exploration.
                Morris Van Horne
                1954 Commander
