I have 4 stuck valves on my 289. Stuck in open, spring compressed position. Any advise on how I might be able to free then up without removing heads? Thanks Jim
Need Advice and/or opinions on stuck valves
Remove rocker arms.
Spray valve stems with PB Blaster
Next day, strike valve tips solidly with a brass hammer or hold a brass drift in line with the valve stem and strike with a 2# hammer.
If they don't release first time, repeat process until they do.
jack vinesPackardV8
Just curious, do you use any gasoline additives? I know that several friends with Ford Y Blocks that used and maybe abuse lead substitutes and had stuck valves after letting the engine set for a week or so. It took a tear down to finally correct the problem, and no more additives were used. as an added bonus.Originally posted by Farrier1951 View PostI have 4 stuck valves on my 289. Stuck in open, spring compressed position. Any advise on how I might be able to free then up without removing heads? Thanks Jimsigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
Actually it is Moisture getting into the engine and long sitting that usually rusts the Steel Valve Stem to the Cast Iron Valve Guides on open valves, with no lubrication.
If you sealed the exhaust Header openings and the Carb. opening before storage you would have a better chance of a turning engine years later...(most times).
If it has been parked in a field and left for years unprotected, little to NO chance.StudeRich
In doing this job remove the spark plugs (I assume you already have) and assure the cam position with the stuck valve is TDC follow your firing order around. As said in previous, reach in through the sparkplug hole with a drift, brass or hardwood and tap on the edge of the valve until it reseats. Turn the engine over by hand until that valve is pushed up if it stays up repeat the process and relocate TDC. This process could take 1-3 days to complete it is not east but doable, also lubricate the valve stem as required. I have done this on several engines and it is time consuming. Do not over strike the valve as it may cause damage, steady gentle taps. Best of luck Dave
There's something to keep in mind once you get the valves freed up, and I had this happen on the 289 in my '55. You should be able to press down on the valve with the spring, and it should compress, and return to its original position. If it doesn't, either the valve or guide is still corroded, or the valve stem itself is a few thousandths out of tolerance, and is bent. The latter requires removing the head and replacing the valve or valves. When I got mine out, the "bend" in the middle couldn't be seen, but at the same time, when it was operated inside the guide, it would stick in the valve guide, which the replacement valve didn't do.1964 Studebaker Commander R2 clone
Originally posted by Farrier1951 View PostWow. Dave I had to read your post three times. Reach in through the spark plug hole and tap on the edge of the valve? Really? I'll be doggone, never would have thought of that. Not pulling my leg......right? Jim
I freed up 4 stuck valves in a 259 earlier this year. Just took off the valve covers, found the stuck ones, and tapped on the valve spring retainer with a hammer and a drift, as needed. Sprayed lots of Liquid Wrench, too. The first one (#1 exhaust) was the hardest; the rest came pretty easy. I didn't take off any rocker arms. I did try to make all my hammer blows along the axis of the valves.Gord Richmond, within Weasel range of the Alberta Badlands
Well folks to update: Took in all the advise offered and managed to free up 3 of the 4 stuck valves. One however on the drivers side seems almost welded in place. It even sounds different than the other three when tapped with brass hammer. Anyway, the push rod for the still frozen valve is also bent to resemble the big slow "S" in the Studebaker logo. I am now thinking I had better just pull the head and get that valve out of there. And I guess it will let me get a good look at the cylinders on that side too. What do you think? Should I just go ahead at this point and pull both heads to do a good inspection? Also I have two good heads on the 62 engine I have. Would they be a straight swap? Thanks for all the valuable advise guys I really do appreciate it. And Jerry Blount thanks for the push rods. Looks like I will need at least one of them. Thank you one and all. Jim
Originally posted by Farrier1951 View PostThasnks Jack. My friend Jerry Blount said the same thing. Just couldn't remember.
I had a 62 Hawk that had set for years with the same prob. on 4 or 5 valves and they finally freed up. When free, put a BIG dose of Chevron Techron in the tank and drive it good & hard.
Worked for me!
Good luck & report back please1996 Impala SS
1967 Jag XKE FHC
1963 Avanti R2
1963 Avanti R1
1956 Packard Patrician
1948 Jag Mk IV DHC
1909 Hupmobile Model 20
