Positive ground, 6V system coil
  • Ignition: Positive ground, 6V system coil
    I did a search but couldn't find an answer. On a 6V positive ground system, does the positive side of the coil go to the points or the negative side? Thanks Tom
    No mystery, it goes to the same place as a 12 Volt, Hot to Ign. Switch (-)
    And Ground to ground ie Points (+).
      Huh? I think someone is gona be confused. It's the same but different?
        ign
        Positive to the points
          Yeah, this is correct, but the way it's phrased makes it quite confusing. Positive ground = plus side to points, negative ground = minus side to points. 6V or 12V, same same...
          Corley
            Think of it this way: where does a coil "see" ground? From the points.
