Air cleaner (new picture)
  • Air cleaner (new picture)
    I have a Stromburg WW 2 barrel and very interesting air cleaner (Stock 1959) for it. On the top of the air cleaner there is a hole for a threaded stud to stick out of, so you can spin your trusty wingnut on and tighten it down to keep the nastys out of your carb/engine. [}] Here is were it gets interesting, there is not a spot in or around the carb for the threaded stud. I'm sure that if my repair manuel were not in storage I could easily look this up and save everyones time. I can't figure it out, am I missing a part or two? [V]
    Randy_G
    1959 Lark Sedan
    www.AutomotiveHistoryOnline.com
    You need the factory clamp on adapter with built in stud.
    JDP/Maryland
    64 Daytona HT/R2 clone
    64 GT R2
    63 Lark 2 door
    58 Scotsman
    52 & 53 Starliner
    51 Commander
    39 Coupe express
    39 Coupe express (rod)
    JDP Maryland
      Randy, this is the only picture I have of my carb with a reasonable view of the airhorn. There is supposed to be a bracket that attaches to the airhorn and the stud is attached to this. This is a Stromberg WW on the 1964 289 engine I bought. I hope this helps.
      Tom - Valrico, FL
      1964 Studebaker Daytona - 289 4V, 4-Speed (Cost To Date: $1903.98)
      Tom - Bradenton, FL
        Thank you John, I knew it was missing something. [xx(] I have no idea where I will find one of these little jewels![V]
        Randy_G
        1959 Lark Sedan
          Bought mine NOS at SASCO last month.
          JDP/Maryland
          64 GT R2
          63 Lark 2 door
          58 Scotsman
          52 & 53 Starliner
          51 Commander
          39 Coupe express
          JDP Maryland
            Any chance someone has the part number, I purchased what I thought was one but I'm guessing I gave the wrong discription of what I wanted because when I got it in the mail it's not the same clamp as Tom has pictured above. Thanks for all your help.
            Randy_G
            1959 Lark Sedan
              Randy, it may not be the same as Tom's, but will it work on your car? Never hurts to ask.
              Matthew Burnette
              '59 Scotsman
              '63 Daytona
              Hazlehurst, GA
                No I tried it, it to small of a diamter. I would not even attempt to guess what year Stude it fits.
                Randy_G
                1959 Lark Sedan
                  Send me your address and I'll send you one. just replace it if and when you find one.
                  JDP/Maryland
                  63 R2 SuperHawk (Caesar)
                  spent to date $54664,75
                  64 R2 GT (Sid)
                  spent to date $62,839.60
                  63 Lark 2 door
                  51 Commander
                  39 Coupe express
                  JDP Maryland
                    Randy, sounds like you may have bought a 6 cylinder one.
                    Matthew Burnette
                    '59 Scotsman
                    '63 Daytona
                    Hazlehurst, GA
                      JDP, I sent you a note off forum,
                      This is the clamp I purchased perhaps someone can help identify it.
                      Randy_G
                      1959 Lark Sedan
                        Looks like the clamp to hold the air cleaner on a 50's Champion 6.
                        Bellingham, WA
                          Dick is correct, this is the clamp that goes at the bottom of the old United oil bath air cleaners to hold them in place. Perhaps JP will take it in trade???
                          http://community.webshots.com/user/GuidoSalvage
                            Randy; looks like you've got a job to do...get that Chassis Parts Catalog out of storage!! [:0]
                            Studebakers Northwest
                            Ferndale, WA
                              Dodge trucks (as well as many other vehicles) used the Stomberg WW forever[]. We had a '65 318 with that type of clamp, and my '56 259 Dodge p/u had that type of clamp, also. So you might check local wrecking yards and see if they are the same.
                              KURTRUK
                              KURTRUK
