Need A/C pics
Claude Chmielewski
Studeski
http://www.studeski.com
Fillmore, Wisconsin
47 M-16 Truck
53 Commander Regal HT
53 2R5
60 Lark VIII Convertible
60 5E7 Champ pickup
62 5E7 Champ no box
62 GT Hawk 4 speed
63 Lark VI parts car
63 GT Hawk R2 4 speed
64 Commander Wagonaire
64 Daytona Convertible
50 Champion Regal (parts car)
36 Dictator
36 Dictator in piecesTags: None
References to Hawk but not with a/c.sigpic
Claude Chmielewski
Studeski
Fillmore, Wisconsin
47 M-16 Truck
53 2R5
60 5E7 Champ pickup
62 5E7 Champ no box
62 GT Hawk 4 speed
36 Dictator
Studeski
Do you have the brackets to install? In some GTs I've seen a long bracket that attaches to the evaporator as opposed to the Lark type brackets. It appears to aid in keeping the dash from cracking as it's 'glass. I haven't put the A/C in my '64 GT yet so can't help with dimensions & my buddy's GT w/A/C is all packed in the garage . Can you get info from the templates available through the Forum resource? Rob in PA.
Originally posted by studeski View PostI am installing A/C in my 62 GT Hawk. I need pics of the evaporator install. Hanging brackets. Distance from right kick panel.
Thanks
[ATTACH=CONFIG]26070[/ATTACH]
http://web.archive.org/web/200808031...int3.jpg-.htmlJDP Maryland
Originally posted by stude1964 View PostStudeski
Do you have the brackets to install? In some GTs I've seen a long bracket that attaches to the evaporator as opposed to the Lark type brackets. It appears to aid in keeping the dash from cracking as it's 'glass. I haven't put the A/C in my '64 GT yet so can't help with dimensions & my buddy's GT w/A/C is all packed in the garage . Can you get info from the templates available through the Forum resource? Rob in PA.sigpic
Claude Chmielewski
Studeski
Fillmore, Wisconsin
47 M-16 Truck
53 2R5
60 5E7 Champ pickup
62 5E7 Champ no box
62 GT Hawk 4 speed
36 Dictator
Thanks
Sorry I don't have pix, but if I could find the brackets I'd mail them to you. I likely threw them away, along with most of the rest of the OEM AC stuff.
Originally posted by JoeHall View PostI removed the OEM AC from my 63GT (only thing left is the weird hood prop rod). Looking at your pic, if you move the unit to the right about 2", to where the upper left corner of the unit just kisses the edge of that lowered, driver's side corner, then raise the unit to about 1" below the wide, flat surface of the lower dash, you are right on target.
Thanks for the reply. It looks like the right fender vent lever would have to relocated then.sigpic
Claude Chmielewski
Studeski
Fillmore, Wisconsin
47 M-16 Truck
53 2R5
60 5E7 Champ pickup
62 5E7 Champ no box
62 GT Hawk 4 speed
36 Dictator
Originally posted by JoeHall View PostSorry .......if I could find the brackets I'd mail them to you. I likely threw them away, along with most of the rest of the OEM AC stuff.
Doing so to someone desperately in need of said parts is doubly cruel.
Repent and seek forgiveness.We hypocrites of the "brotherhood of gathered deteriorating rusty parts" await your absolution.
However, if yours needs to be bent a little, it will easily bend anyway it needs to go, just like a can lid. You'd have to bend it back & forth several times to break it. I bent, even contorted the heck out of the one on the 62GT to accommodate the EFI harness, which I chose to bring through the firewall right behind it.Last edited by JoeHall; 07-24-2013, 09:34 AM.
Originally posted by PeterHawk View PostJoe...Could that weird hood prop rod have been bent to clear the the condensor in front of the radiator?
That would be my guess, though the other type clears just fine too. This one does not have the crook on the end that goes into the hood lip when raised. It is also a couple of inches shorter, which causes the hood to sit a little lower when propped open.
