Hot Rod 101 Steering column
  • pszikszai
    Thanks, I am done with it.
    Paul
  • N8N
    Studebaker did some weird stuff with driveshafts... "broken back" driveshaft setups, U-joint angles larger than "the book" says will work, and u-joints slightly out of phase for some reason...
    55 Commander Starlight
  • Guest's Avatar
    Guest replied
    When I look at the way Stude offset their engine to the right it appears to me that the engine is angled. Am I mistaken? I thought that was why they put that big spacer under the rear mount for the Flight-O-Matics.
  • Mike Van Veghten
    What Nate said!
    You will notice...most ALL of the OEM's do it also!
  • N8N
    absolutely. just don't angle it; the pinion and the trans tailshaft should be parallel to each other.
  • pszikszai
    started a topic Hot Rod 101 Steering column
    I am in the process of rebuilding a 1947 M truck.
    The question I have is a generic to any modified vehicle.
    I modified the engine and transmission mounts to fit the V8 engine centering both in the truck.
    Then I put in the steering column, the steering column is touching the exhaust manifold of the V8.
    The question I have is: is it permissible to move engine toward the passenger side , about a half an inch without causing vibration or some other problems?
    Thanks
    Paul
