No power steering after pump rebuild
  • Steering: No power steering after pump rebuild
    I rebuilt the power steering pump on my Hawk due to a bad leak. The system worked fine before I did the rebuild but now I appear to have manual steering! I have turned it lock to lock several times and no improvement. Any ideas?
    Thanks
    Dan White
    64 R1 GT
    64 R2 GT
    58 C Cab
    57 Broadmoor (Marvin)
    Thanks
    Is the pulley key installed? Maybe the pulley is turning but not the pump.
    Allen
    1964 GT Hawk
    PSMCDR 2014
    PSMCDR 2013
    Victoria, Canada
      Dan, I feel your pain. Mine is almost the same story - leaky, then rebuild, now noisy. Had a line on a new P/S pump but fell through. Can somebody supply the name of a P/S vendor?
      Peter Bishop
        If you do a little searching here, you can find threads like this one, which may help.
        http://forum.studebakerdriversclub.c...ring+pump+ford
          I have spent a lot of time looking on the forum for ideas. The one you noted is for a replacement pump, using Ford Bendix for the Stude Bendix. I am going to pull the pump and take pull it apart to see if there is something I missed inside.
          Dan White
          64 R1 GT
          64 R2 GT
          58 C Cab
            Dan,
            I bought my rebuilt pump from these guys last summer on a drive by through Ann Arbor from South Bend. I took all the Studebaker parts off of it, brackets and reservoir, and gave them the core. It is exactly the same as the Studebaker pump and the cost was about $100.
            http://www.npdlink.com/store/product...p_by_year=1965
            Best of luck.
            Allen
            1964 GT Hawk
            PSMCDR 2014
            PSMCDR 2013
            Victoria, Canada
              Well I once again have power steering! I took the pump apart again and found I put the spring on the wrong side of the control valve plunger. How I did that I will never know. I guess too much beer or was asleep. As a tech tip, it is a lot easier to remove the reservoir and pulley while the pump is on the car. It is a whole lot easier to also take the mounting bolts and pressure hose on and off as well without the reservoir in place! The rebuild kits are only $17 from SI and the rebuild is really easy, as long as you put things back from where they come from.
              Dan White
              64 R1 GT
              64 R2 GT
              58 C Cab
