Damn Oil Spray In Avanti
  • Damn Oil Spray In Avanti
    Well, you have detailed the engine compartment to the 9's....you open the hood to check the oil after a run......and there it is oil residue all over the inner fender well....playing a cheap version of Sherlock Holmes you discover that even with the cover on TIGHT oil from the p/s res is the culpret.....with an assist from the top of the fuel pump.....this has been an annoyance from almost new....something else I have had to live with with over 41 years.
    My R1 pump (which is actually an R2 pump) continued to spray oil out
    the vent hole up top. After getting VERY frustrated with it, I came
    up with this "temporary" solution :
    Chances are its sucking some oil too, but for the moment its keeping
    the frame, ram, and control valve oil-free. I dont know at this point
    if the main oil seal on the rebuilt fuel pump is torn again, or if it
    is just from too much blowby in the engine. I need to do a compression
    test to see where I stand ... oil pressure seems too low to me.
    Tom
      IIRC, you can't crank down on the P/S wingnut really tight because somehow the P/S reservoir vents out of the grommet under the wingnut and washer. Hopefully someone else can verify (or disprove) my recollections. If the reservoir doesn't vent, you will blow P/S fluid out places you don't expect.
      I am lazy, so I have replaced the reservoir covers on my P/S pumps with the Ford style, which are vented out of the dipstick/fill cover.
      Another possibility to check would be the gasket under the P/S reservoir cover.....is it old, hard, and compressed? If so, maybe a new one would help if the fluid is leaking between the reservoir and cover.
      Paul
      Visit The Studebaker Skytop Registry website at: http://hometown.aol.com/r1skytop/myhomepage/index.html
      Paul
      Winston-Salem, NC
        Paul,
        Indeed I have a FoMoCo cover with the small screw cap on the top of the cover!
        I have changed the cover gasket more times than I can remember, I just wipe up the mess after a run....I bet a small amount of oil sprays out of the top of the fuel pump (R-1)
        Paul
          Tom, your "temporary" solution looks more permanent than some permanent fixes I've seen!
          Clark in San Diego
          '63 F2/Lark Standard
          www.studebakersandiego.com
            Thanks .. and I did that in the parking lot at a Kragen 55 miles from
            home with basic tools and a mini tubing cutter. Bends are by hand.
            Tom
