generator problem
  • generator problem
    My studebaker was 6 volt negative ground when i bought it. The previous owner had installed some kind of power door opneners on it
    using a 12 volt battery in the trunk for power. (since removed) I
    changed it back to pos. ground, and reversed the battery cables,
    and re-polarized the generator, but I must havew fried the old
    regulator, for when it is running the ammeter bounces off the dis-
    charge peg. I can buy a one wire 6v pos ground aternator
    for around $100.00 dollars. what is your take on this? One supplier
    wants 103.00 just for a 1955 prez. regulator. Any tips on replacing
    the oil pan gaskets? Thanks.
    Don't take yourself too seriously
    1955 President Starlight Hardtop
    James K. Clark
    When the battery polarity is changed either way, the wires on the ammeter must also be swapped.
    So it's quite possible your generator is charging, but the ammeter is reading backwards.
    Dwain G.
      When I pull on the headlights without the engine running the
      ammeter shows discharge. The previous owner didn't bother to
      change the wires on the ammeter when he changed the polarity.
      I think I'll just go with a positive ground 1 wire alternator.
      A local Model A ford parts store will sell me one for $89.00.
      Thank you for your help.
      Don't take yourself too seriously.
      1955 Prez. 2dr Hatdtop
      James K. Clark
        Be careful which alternator you choose. The higher amperage units can overwhelm your ammeter.
        64 GT Hawk (K7)
        1970 Avanti (R3)
