The heater fan motor on my avanti when switched on is noisy making a buzzing sound until it gets up to speed and then it seems to run without making noise. It also occasionally blows the heater fan fuse so I suspect that when first switched on it is drawing high amperage maybe due to worn bearings and bushings. I do not want to pull the dash to replace the motor so can you drill a small diameter hole from the engine bay side at the armature shaft dimple to inject electrical bearing grease or WD-40. I realize this may not permanently fix the problem and the motor may have to be replaced but if it would help prolong the life of the existing motor maybe it is worth a shot.
I would appreciate your thoughts and input.
